What is the thing that goes on top of the deck above the trucks and keeps the truck-bolts from damaging the wood on the deck?
d00d… You’re like Mr. Science…
DKP trucks on the nose with like a 35 deg. Split-angle in the rear is sublime…
Take out the middle-thingingie in the rear and it’s perfect… May have to add a small riser to make the deck flat… But speedy and carvy…
Shockpads or Riserpads
you just don’t get it!
What?
those would be between he deck and the truck
The X-things are called X-things
@akhlut makes some nice ones Stuff Akhlut makes
You can also get them off ebay/amazon
In the hall sensor detection in the vesc tool, can you use a current lower than 10A?
Yes and yes
The current shouldn’t be higher than the rated current of the motor right? My motor is rated at 0,35A, is that too low?
I would not test a 350mA motor at 10A
Maybe try making that a lot lower like 0.1A and see what happens
A esk8 for cats?
If you go into the wizard and do the motor detection from there, there is a place to select the motor mass
How heavy is the motor?
Yes I did that and chose the smallest one, however my motor is only 20g, so don’t know if that makes using the vesc difficult…
I also did try the hall detection at like 0,2A and it did do the measurement but since my motor is not spinning I thought maybe something could be wrong here but then maybe not
You might be in uncharted territory
Haha oh no, this is for my master’s thesis…
Crazy helmets from china I was trawling DHgate for skate gloves and noticed they have some wacky helmets.
I would trust anyone these to save your life
To work out how much in trumpbux multiply by 0.7
Some of them look like they could severely restrict your vision, and others look like they only moderately restrict your vision.
Especially peripheral vision, which is a safety helper
