Don’t use WD40 on any part of an esk8
bike chain lube would be better
gun oil is fine, but not as good
3-in-1 is fine
unused motor oil is even better
3-in-1 is fine
Gun Oil only in america… Smells like freedom
I use Mars 93240 Zoom! Spout oiler
It’s turbine oil, I think.
I’m in the same situation and honestly… go straight for pneumatics.
I got mbs all terrain wheels and they only improved rolling on smooth or with very little cracks asphalt. Can’t wait to get the money for a true london setup
k will try use bike lube
I use a synthetic chain lube i can’t remember the name but comes in a aerosol Can and smells like citrus. Guy in the bike store knew what it was as soon as I mentioned citrus. It leaves a thin coat almost like paraffin wax.
Could you recommend anything mate? Struggling to find pneumatics that will fit that I can get in the UK.
I am waiting for some mounts to come from china for my MBS board but its like waiting for christmas!!
Dual Motors? What is the best dual motor setup for a MBS board? I have read getting two lower KV rated motors at 120kv is the best for dual setup?
@Anubis has some stuff in his shop. He is in the uk.
For pulleys you may want at least aluminium though. @dickyho sells 60t and 44t ones, just have a chat with him. Deliveries seem to arrive in under 2 weeks now from china
Use the esk8 calculator(on the top bar). 120kv seems low for belt drive
Thats a shame because of Covid he’s shut. Hopefully he may open back up!
Message him on here
I will (soon) have his 60T alu pulleys in stock
I must have missed something, they are available for purchase?! ![]()
I can’t decide how I want to mount my Pelican case to my Holypro…
I would prefer to use the red dots for fasteners but I’m not sure if the flex of the deck would not be good in that situation. I could do the blue dots but the fasteners would stick out farther inside the case. What should I do?
Also the distance of the red dots left to right is around 5 inches if that helps.
I did mine like the red. I used some thick rubber washers (5-6 mm) around the bolts, under the box to absorb deck flex and help keep water out.
Are 3.5mm bullets ok for low amp application?
Thanks
Also anyone got the koowheel hubs sensor wiring colour code
I have my old koowheel esc at home, maybe there’s a leftover from the sensors.
Most people call them “X Thingys”, I have also seen “drop through deck protector”. I am not sure if there is a proper name for them
