NeoBox Testing Results V4 (serious)
Original neoBOX Focbox Variant Thread
neoBOX open source Focbox variant (HW 6 Design)
wiki to post results of NeoBox 4 community testing. although this product will quickly be GA i believe community testing should be logged in the Dev Category.
NeoBox 6 Topic Here
Reporting Form:
https://forms.gle/qxgoRUBUQw6Ghh8r7
Upon testing completion please cast your votes for neoBox V4:
    • Recommend
    • Pass
    • Undecided, see specifics in reporting workbook
0 voters
@jeffwuneo
@BillGordon @Skatardude10 @Dred @Bobby @Soflo @itsrow @xsynatic @XBoard @Schulerbible
Final Testing posts linked
@Dred : Final Comments
@itsrow: Final Comments
So now we’re doing reviews of stuff we don’t even have tested?..
how? I can’t even…
This is a placeholder for upcoming feedback from future testers. There is no cause for alarm.
but who was source code?
Capture
@Vanarian
Sorry if I was not clear about the intent of this thread, and the other with a similar name.
These threads were opened in anticipation of the V4 and V6 neobox arrivals and meant as a place for testing results to be posted.
I’d like to change the phrasing in the topic and description to avoid further confusion - what leads you to believe the topic is intended to provide a review?
Hi all, please use the below link for submitting detailed issue/error reporting, the form includes options for the V4 and V6 models, I will post this link in the V^ thread as well, if some one could pin this would be super handy.
Reporting Form:
This is a very thorough document, I like it a lot! Looking forward to seeing testing results.
@Dred. I just checked out the form. Is that something we fill out w each report? Or is it a continual log? I’m asking because I ordered both the 4&6 versions. And the form doesn’t allow both as an answer.
Is this compatible with metr log data or only vesc/vdla type logs?
General PSA:
NeoBoxes are arriving and community testing is beginning. lets work to honor the serious tag from this point forward. i refreshed the poll to capture meaningful votes
above note is not directed at individual or comment but rather a line in the sand
Im waiting for someone to perform an open loop test at 80 amps
Goto the terminal
Click heartbeat on
Foc_openloop 80 3000
Need to make sure the motor settings are above 80A
Time it until it hits thermal throttle (80 deg C)
I will test this and report back.
so i accidently clicked to vote and now its there forever. my b
Delete your whole account
Sorry missed this, ideal format would be .txt or .doc for log files
You fill out for each issue you encounter for each hwd version, aka if your v4 blows a FET and your v6 is randomly pulling to many amps they would each be entered as separate line items for f that makes sense.
