Thank you for sending the log file. I see in the logs that UART communication is not stable. I suspect it might have to do with physical connection. I recommend additionally securing your Metr Pro UNITY with double sided tape and it might be a good idea to put a drop of silicone glue on the connector after you plug it into FOCBOX UNITY. It might be tricky, but very important that you do it.
Recently we discovered a few cases where Metr Pro UNITY even popped out of the connector completely because of strong vibrations. FOCBOX UNITY silicone cover did not prevent it from happening.
A few questions, can it record data in higher sample rate than the 300 ms of MetrPro? And any estimates of how long a card can record? I guess pretty long even for a small card
CAN is available on both of the front JST GH connectors. So you can plug it between two VESCs, one powering the Metr Pro CAN and the other ESC only gets CAN forwarded.
There is an extra JST SH for the GPS.
It didn’t work well (once again). Then I try to factory reset the watch and now it seems that the Metr Pro app doesn’t want to install on the watch (Sony SmartWatch 3 SWR50).
