So you tried to update Metr Pro CAN first and it went well, right?
But you are having issues with original Metr Pro. Not sure why, try to Unpair in system settings / pair again in Metr app / try to update again.
correct
correct.
will do
Still times out. What also happened is that after i tried to switch to another metr the app crashed and kept crashing until i force stopped it and cleared cache.
Do you have another phone to try update with? If not, maybe installing older version apk will help, https://apkpure.com/metr-at/at.metr.app/variant/4.6.14-APK
Using my oneplus one seems to have done it. Although it did also crash when switching from metr can to pro.
Oneplus one runs App version 4.6.14
Oneplus 6 runs 4.7.9
I guess its the module causing it?
I suspect Android bluetooth drivers that are causing it. Some phones work, some donāt. However strange that the same phone worked for one module and failed for the other. I will look into crash when switching, thanks for reporting.
Can relate, tried updating and keep timing outā¦ Xiaomi Redmi K20 Pro, Android 10.
Tried with Android 6 phone for giggles, didnāt change anything. Neither did another Android 8 phone.
hmmā¦metr can disconnect ls every few seconds.
going to try metr pro
nope, happens too.
updated log:
log_2020-12-01.txt (2.8 MB)
Does oneplus one with 4.6.14 also disconnect?
Canāt tell you as Iām riding the board. Can tell you later once Iām back.
4.6.14 down from 4.7.9 downgrade allowed me to update the module firmware. FlexiBMS 0.15 seems to work now. The module disconnects in a timely manner every 30 seconds thoughā¦
I had this update problem the other day tooā¦ Then it just worked all of a sudden and Iām up to date now
Samsung galaxy s10+, android 10
Update: New app(4.7.12) makes new firmware work kind of okay.
Butā¦
New app doesnāt work with previous firmwareā¦ Completely doesnāt connect even though phone sees that Metr module is available.
New update coming soon with big fixes to Stats and Sync
- Stats are now calculated based on records (previously they were stored separately)
- If you remove some records, stats will reflect that
- Stats are no longer editable or resettable
Sync All in account tab now will
- Upload new records to the cloud
- Download old records missing on the phone (useful when you migrate to a new phone)
New stuff added to stats:
- Average distance
- Record count
Removed from stats:
- Top speed
how come? i liked those features. itās good when you change setup like bigger or smaller wheels, or on your first few rides with the board before itās āāreadyāā.
and top speed is like THE reference point
Usually you know your top speed (approximately). Top speed is more interesting when you look at a single record. Also sometimes people smash throttle when wheels are in the air / on the bench, which just puts a new high value for top speed.
so true, i didnāt think about that!
Lovely!
Small update, mostly cracking down on bugs and compatibility with latest releases
- Support for VESC FW 5.2 and FlexiBMS 0.17
- Fixed a few LLT BMS connection issues (thanks to @MartyMcFly88 and @ShutterShock for reporting and to @mackann for providing a test board with BMS)
- Also thanks to @xsynatic as always finding some bugs, this time with Announcements (very underrated feature by the way, please try it)
- Import Modes by clicking āImport modeā button in the browser (thanks to @xsynatic for suggestion)
- Display BLE pairing status on Realtime tab
- Fixed search bar in Expert tab by removing predicted text input (discovered it with @mackann today)
As always if you find new bugs, please collect the log file and let me know, you know the drill
