What about Android Wear support?
Latest version crashed often and refused to re-open without restarting phone…
I wonder why metr is getting worse and worse with me. It used to be so nice
Should I even try metr tele for 4 unitys? They are on firmware 5.2 with @b264 supersingle Mode
I mean, I’m going to unless this will cause definite fire and tears. In which case, someone please say, “don’t, idiot”.
Please try it! I don’t think it will cause fire
Curious what you get! I don’t think anyone ever tested this before
What is this? im away from my board but curious to know! I dont think ive ever noticed it
You’re not wrong there.
You can set “Announcements”
for example metr announces a certain set stat every X seconds with a voice through your speaker/headphones.
“Voltage at 49”
“Speed at 32”
“Temperature at 78” […]
You can set when it starts and when it stops.
Let’s say metr tells you every 30 seconds the current temperature between 65c and 95c if you want.
Really awesome if you don’t have a davega or want to look at the phone to check how things are doing.
im definitely going to use this for duty cycle
oh wow I didnt realise it can do that, thats super useful
Thats cool, similar to running apps
Yup it’s nice to set parameters up to let you know your about to hit butt hole clenching or if you need to find a spot to charge haha
¿Que? What is that?
Total fluke in the app. Happened yesterday and I thought of you… Ha
Happens to me occasionally too but not with the pairing thing
I’m having some trouble with motor detection on my metr pro (haven’t tested with CAN yet)
When the vesc is set up for foc and i do a foc detection, the motor just stutters and gives a failed motor detection message.
To solve it i have to pick BLDC, do a detection without writing the settings yet. After the bldc detection is done i write the settings, switch to FOC and then i can do a motor detection that passes.
Also happens when i successfully did a foc detection and want to do it again, it just stutters and fails.
I’ll try to do a video and send the logs later.
What duty cycle do you have in detection dialog? Try to bump it up a bit and see if it helps. Same with current.
Whatever Metr has as Stock. I’ll check in a sec.
Might want to add that the problems so far only appeared with unsensored hubmotors.*
I think i mentioned it already back in the day: It would be cool if we could access the Expert tab and it’s features while not being connected (to check on stuff)
And i sometimes get unknown error/fault at the start of the metr pro connection. Takes 2-3 seconds until it goes away and the regular connected status comes on. Sometimes reconnecting after a board powercycle only happens after killing the app or switching to a different metr module and back.
Update:
I got an unsuccessful detection at stock settings, did one again right after that also with stock settings and it passed. So Sometimes it’s random it seems. I’ll try to get it to fail mutliple times to try the upped duty and current settings.
Update2: now i can’t get it to fail lol.
Suggestion 2: Make the “Writing” process more visible. Wasn’t it Red and green earlier?
Suggestion 2.5: If it won’t be colored maybe also put a percentage counter on the settings writing process like with the updates.
