This day on Nov 22nd, 4 years ago Metr project was launched
Since then it has been non-stop development with new products, a lot of new features and improvements. All of that was possible because of this awesome community and we would like to say thank you! For your feedback and support
Today we are finally ready to offer our new module - Metr Pro CAN. Some of you got tired waiting for this one but we really wanted to make sure everything was done properly
The new module has all the features of the old one plus more, one of the biggest changes is that it now connects over CAN. Which means you can use UART port for other things!
We went with a modular design keeping the base model slim and affordable. We knew some of you just needed the CAN option!
For those of you who want offline logs, not taking your phone on a ride with you, we went ahead and added an SD card shield with optional GPS module. We partnered up with @SabreDynamics who designed us an awesome 3D printed case.
All models can be configured with external antennas.
We are really happy with the design, the modules are very compact.
The small battery keeps RTC alive while the module is powered off to keep track of the time. While @janpom was beta testing one of our units we came up with a cool little idea, DAVEGA fetching current time from Metr Pro CAN and displaying it. We plan to do more integration down the road. Also big thanks to the rest of our BETA testing team @xsynatic @visnu777 @rene who helped testing since May.
Specs:
- Dimensions 30mm x 22mm x 8mm (base model)
- Dimensions 37mm x 27mm x 17mm (3D printed case)
- 2x JST GH to PH 150mm cables
- Supports 125K/250K/500K/1M CAN baud
- Automatic CAN baud detection
Every existing feature of Metr Pro that you might expect including:
- Plug and play setup
- Up to 4WD realtime data
- Secure BLE with PIN code
- Over-the-Air updates
- Optional external antenna
Each module is carefully assembled and tested by @hexakopter in Germany. The assembly has already started, we are just waiting for some cables and parts.
We expect to start shipping orders mid December
Prices before VAT
| Metr Pro CAN | €59 |
| Metr Pro CAN + SD card shield | €89 |
| Metr Pro CAN + SD card shield + GPS module | €99 |
| External antenna | €12 |
Order now at https://metr.at/shop
If you have any questions, let us know
