*don’t follow all the steps if you want to use it as a 12S.
Anyways I got one and I kinda want to get another to try it again without removing the Balance PCB like he does in the video.
One cool thing I thought of is because there are 3 terminals on the battery, you can have the two main battery terminals and then the BMS charge - on the 3rd terminal. Then the charger would hook up to that and the main battery pos. No drilling in a charge port!
yeah, I need to add to the post how the whole top of the battery/case is actually a interesting water-cooling block. So I’m dying to put one super powerful ESC on there, and also hook up the motor to the cooling loop. That would be a first I’m pretty sure.
This is to test it while I figure out how to use the plastic terminal thing, basically buy the ring terminals and get the bluetooth dongle wires to go through it.
top mount esk8 for now but it’s just a giant aluminum battery with a bluetooth bms for all your 19Ah aluminum battery with a bluetooth bms for <$200 shipped needs
