Salvage the box. It’s a beauty. Put some k wool inside and you’ve got a wicked fire box
these are the cells apparently. someone says this is not it.
@Flasher I was hoping to use the spim08 cells in there because they are the most susceptible to damage so they could actually take advantage of the super strong box unlike cylindrical cells. They would also be able to dump their heat into the case very effectively, hopefully I find a way to fit 24 in there.
Minimize wiring and that should be easy. Jehu Garcia uses those and installs grommets to hold em together
the way I showed is the only way that they seem to fit in. I’ll show you how close it is.
I wish
nah
I guess the best way actually for these cells but shit use of space.
12 stacked next to it.
These cells fit way better in the apache cases, so that’s my plan for them mostly.
Snapchat-96922794
After some subtle convincing the BMS has parted with the cool output screw terminals. I definitely would not have been able to desolder those easily.
Maybe go bigger and can sit on it! Seriously. Add some pedal levers on the hanger. I wonder how that would go.
I think u should get those too. Highest energy density of iron cells I’ve seen. Less powerful though. And the label.
look my credit card is -1000 i got problems
what about the label? Don’t like monkeys on your battery cells?
Someone tell me if I should make a dedicated thread instead of hailing on this one.
I realize that I 100% should use the battery along with it’s case.
The BMS was so huge (33mm tall), taking it out gives enough room forx VESCs and a new BMS.
I also realized the bluetooth BMS prob would not work inside the metal box so I had the idea to run them on the outside and use the pins in the case to transfer data in and out. There are 8 pins, 4 are needed for the BMS leaving 3 for a PWM signal and 1 extra.
our main man Tom Amerman bringing the tesla goodies.
I like the monkeys on the cells.
Batteryhookup! I like their attitude and drive. I’ve got tons of the fancy bms that came with the cells i got. They probably cost more than the whole battery new but they’re huge and don’t know how to use them
I got the bit to take apart the EMC packs but it needs to be longer and an extension won’t fit.
Drilling might have been attempted
I actually haven’t taken any apart and @evoheyax was doing them. Together we spent 4000$. Damn u batteryhookup. Have to make more vehicles. My selling them with the pcb was the plan but with no marketing and no decks at the moment to go in they just sit here. But decks will come.
How many did U get or is that all in that box?
I got one of these Mercedes 880Wh. Kinda want another for the case and the battery because it is sick af, just heavy altogether.
look at the beef on this BMS
Would be awesome if it worked.
This is the connector I need to desolder to use the ribbon cable.
See the case? yesh those bolts came out with pliers not screwdrivers. Smallest torx ever would be needed.
I put the BMW 16s pack in my City Coco scooter. It was so fast and went like 40miles or more. Then the stock 1000w 30a controller died. Totally worth it. Now to vesc it up. lol
the bms probably works though no? i assume all the ones i have work but just dont have a guide or use. i forget the brand but top quality stuff and huge. somewhere someone wants it
it would require some secrets to activate I think, I meant if the battery was working out of the box. Plus with taking it out I get room for stuff, get to add bluetooth.
I would rather invest my time into trying to make the world’s first water-cooled Esk8.
