You mean the little 2 pin port next to the uart?
If so, yes, it is just a gnd and v+ connection and works great for battery meters.
Yeah thatâs the one.
Will it turn off with the ESC power switch?
I was thinking about wiring a meter into another ESC, and realised I would have to solder to a point past the Anti-spark to avoid it being an always-on battery meter.
Yep, turns on and off with the integrated esc switch
Amazing! Good one guys, excellent feature.
I am running 4WD with 100D v2. Normally they do the job perfect but sometimes they act very weird. The vescâs are connected over CAN. The powerswitch is placed parallel over each stormcore.
1: When I use the vesc tool, only 3 vescs are seen. When I disconnect CAN and I switch connection between each stormcore, I can see 2 vescs on each stormcore with the integraded CAN. Now I set everything up without CAN connected and then connect CAN.
2: I was driving and suddenly the board started to brake slightly while I was using the throttle. When I stopped, the board only went backwards as I pulled the trigger (when it normally has to go forward). Turning the stromcores off and turn back on fixed this.
3: Smart reverse sometimes works and sometimes it doesnât.
4: While doing the âSet motor FOCâ wizard (Integrated CAN), each time one vescâs shows that the motor is sensorless. When I do each vesc separately, each sensor is detected.
Have any of you experienced these things?
No. 1 is a bug in FW 5.2. 5.1 and 5.3 donât act that way.
No. 2 might be a bug with your remoteâs receiver. I have heard of this happening to someone before I think, but before stormcore was even a thing.
No clue on 3 and 4.
Try Hyst Reverse or Current
What remote are you using?
They look slightly off
This happens for me with 60D+ each time. One motor detects as sensorless and also the other detected parameters are little bit off. Running motor detection twice fixes it.
The body is certainly 126mm. But I donât think the outer holes are actually at this spacing.
They look more like 125 / 125.5mm.
Which is probably enough of an error to give me issues as I was hoping to tap these holes.
Thanks for the drawing, thatâs helped me confirm the rest.
That document I linked is a wiki, so if you find errors, yeah, you can edit it.
i have an stl file of a mocc 100D if youâd like
i have the first version on my github iirc, but i made a couple ectra changes
includes holes, ports, the whole lot
Got my new eboosted enclosure in. Looks to be about 3cm deep.
From the above schematic the stormcore is 24mm tall so this should be fine right?
ya, should be no problem!
padding up top just gofor some cussion or whathave you
you got space
Pretty soon will be the launch of the next VESC tool, the beta is linked here. It should contain fixes for the majority of things you mention. I think it is pretty mature these days if you want to give it a test and see if it solves things for you.
Please report back anything it doesnât solve. Iâve been more directly involved in the development and should be able to integrate changes reletively quickly before the next release.
Is there anyone around that knowâs about repairing stormcores? I messed mine up. My fault. Theyâre kinda pricey to just throw out, especially if it can be repaired.
Yes but Iâm in Sweden so it might get expensive
New setup with a Stormcore 60D+
I should be able to use a Metr + VX2 on this setup correct? Can I use the UART3 for the remote receiver? Currently UART2 works but UART3 doesnât get any data/signal from the ESC.
Firmware 5.3 is what you want to get access to the second uart port
