I have that same issue with my Unity. I’ve checked everything. changed motors changed to a new Unity, new remote, fw re-write. I haven’t checked sensor-sensorless transition seetings. can you tell me a little more about this setting?
I have the same problem, how does it feel when you ride. are you getting this micro braking feeling while accelerating?
Page @JohnnyMeduse < North america repair wiz. If anyone can fix it he can.
Does anyone have latest focbox ui version for pc to send me? Cant find mine and enertion site is down
Should have it on my pc will check soon.
The enertion boards github won’t be taken down and it is hosted there.
What’s the most reliable Focbox Unity FW? I believe I heard it being 23.46 but just checking…
are you planning on running a motor temp sensor?
you’ll experience minor cut-outs from poor thermal sensor temp readings on 23.46 causing throttle cut-outs “glitches”
you can turn motor sensor throttling off… de-pin the motor temp sensor… or wait till the problem is solved in beta version 5…
I’m planning on using temp sensors
So there is no FW that works on temp sensors so far? Sorry for sounding stupid, never really kept track of Unity…
I’d encourage going with FW 5.0 we have added some new filtering to motor temp sensing. Testing has been favourable.
Also not all motor temp sensors are created equal. We never had issues with our temp sensors in raptor hubs.
read what I wrote you goof!
and start reading from here down:
I had ZERO issues on 23.46, DIYd a temperature thermister on some motor and then I observed some throttle glitchyness…
Alan had the same… @drone001 had the same issues… he turned off temp sensor throttling and now zero issues…
I could do the same or upgrade to V5 beta… but I’m going to attempt to wrap the sensor wire around the phase wire runs to clean up the noise caused by long runs of parallel phase and sensor wires… and maybe copper foil shield the sensor wire… FIRST
Sweet! I’ll just turn the throttling off then!
just wanted to add that i had a friend whos board was saved by the thermal throttles this week.
he was out riding and started to loose power. stopped to check everything and one motor was scalding hot.
Turns out one of his gearbox’s shifted somehow and was causing loads of extra friction. but thanks to the thermal throttle no lasting damage was caused.
I usually stop when I smell burning enamel and grease… hahahaha but this is a valid point! @DEEIF hand check your motor temps, especially on a new build, until you get a feel how they run…
Like we do on new set-ups on qwads!
or go straight to beta fw v5
I have been running FW 23.46 without issues on some TBDD’s. I generally don’t hit my temp limit unless I’m doing repeated drags on 80 amps so I rarely have a chance for temp throttling glitches. Also, this is the first I am hearing of this so it’s news to me. Lightweight, flat roads FTW!
I’m assuming you mean 23.46 but same here, motors at 80A and no sign of issues. I do have my thermal throttling on but set at the max 135°C lol
that’s great news… I was unaware that the TBDD had temperature sensors…
Yes, good catch! No sense in causing more confusion. Edited above accordingly
Also I have mine set to start throttling at 80˚C if that makes a difference.
The 2nd batch+ do I think. The 1st batch did not IIRC. They are great BTW thanks for asking lol
