No, the title isn’t clickbait unfortunately. Two weeks ago I made the decision to quit my job so that I can focus my time on starting my own business. This means I no longer have a source of income to fund this hobby, and although it’s been a fun 4 years, building and repairing skateboards is a massive time sink for me.
Going forward I plan to finish the boards I’ve already started work on, but anything new is likely going to be a prebuilt from Hoyt or another quality brand. I’ll still be on the forum for the foreseeable future, and I’m currently editing all the videos from Carve PDX this year, but after that’s done I don’t know what the future of my esk8 adventures look like.
Anyway, here’s all the parts I’ve accumulated over the years and am offering for sale! Shipping is from Latvia and should cost around 10€ to anywhere in the world for most items that aren’t huge. Since I am clearing my room then expect prices to get lowered if stuff doesn’t sell, and feel free to ask for discounts if you buy multiple items
Stuff I want to get rid of:
Idea 113mm motor mounts for 200mm Surf Rodz RKP hangers. 60€
(You can ask Idea for a different truck mounting clamp to use these, that’s why they’re so cheap)
Bowery Surf adjustable baseplate for Surf Rodz RKP trucks. 25€
These baseplates also allow for negative angles, so you can mount your trucks in reverse for better wheel clerance / crazy setups
50 degre Surf Rodz RKP baseplate in black. Used. 15€
Nese 12s3p 18650 – 20€
Slight arcing marks on this which you should clean off.
12s 10A YZpower charger – 60€
Caliber 50 degree baseplate – 10€
Used, taken off my shortboard.
Newbee RTKP truck (gen 1, 340mm hanger with shoulder bolts) – 100€
Flipsky 190kv 6374 8mm stepped shaft motors, heavily used – 50€ for both
They’re missing bullets and sensor connectors.
Non-esk8 items
Sony FE 16-35 F4 zoom lens – 850€
Used, but glass and electronics are in perfect condition. Original lens cap broke, sturdier 3rd party replacement is included.
NiSi Pro Vario True Color Variable ND filter, 67mm diameter. 50€
Sold items
Click to see what you missed
Bestech 12s D140 BMS – 8€
Has leads for a NESE setup.
Bestech 10s D140 BMS – 5€
Idea long motor mounts (113mm CC distance) for Apex Air / Luna / 22x22mm trucks – 100€
480T HTD5m 15mm belts – 15€ for all 4
Moon 72T pulleys for MBS and Trampa pattern – 40€ for both
Flipsky 190kv 6384 8mm shaft BH motors, used – 130€ for both
One is nearly new, both work perfectly, both been used.
Surf Rodz 200mm RKP trucks with 10mm Boardnamics axles and Idea 113mm mounts – 140€
Baseplates not included, see next listing.
Sony FE 20mm F1.8 G lens – 500€
Used, perfect condition. Filmed my CarvePDX 2022 footage on this bad boy
OSRR Albert remote + receiver – 300€
Things to note:
The throttle is knobless because that’s what I prefer for fine grained control
The screen has the top rows glitching a bit. Replacing it should be cheap and easy I’ve heard if it bothers you.
The USB port might not be soldered correctly, because I was unable to update the firmware on it. Not that there’s really a need to, development on this remote seems to have stopped.
Price is high because
- it costs a lot new
- this is THE most reliable remote on earth
- it’s got built-in telemetry and odometer features ffs, to replace this I need buy both a puck and a davega
- It’s unobtanium of course
Selling because I know I’ll crash with it one day and that’ll be that.
Kaly XL deck with double stack eboosted enclosure and 12s8p P42A battery with LLT SmartBMS – 1400€
Was thinking of building something cool but having 2nd thoughts. Had trucks mounted to it and griptape applied for testing. Otherwise completely new. Battery build by myself.
Slightly blemished Ramm deck, regular flex – 190€
I found the camber too aggressive for a street deck. Should be incredible though with bindings / as a mountainboard. Idk what the blemishes are supposed to be, it looks fantastic.
Green 100mm 83A Boa wheels with kegel core – 60€
As you can see in the pic, one core is slightly cracked from me hammering these off and on of my gear drives. I’ve never seen a kegel core failure and I don’t think this one will be problematic as long as you use it as a front wheel.
Lantyachtz 40" Evo with double stack Big Ben enclosure – 280€
Was going to build a battery for this and sell as a complete. If you’re form Europe and you do want this and want me to build a battery for it / turn it into a complete, reach out!
More pics here:
[EU] [Norway] Evo build for sale.
190kv 6355 Maytech motor with 8mm shaft and 4mm bullets, used – 40€
150kv 6374 Maytech motor with 8mm shaft and 4mm bullets – 60€
One bearing slightly loud, and a few scratches from storage. Otherwise basically new.
Matrix 2 trucks with orange shockblocks, Batch 1 Moon drives with rusted parts. 9T pinion for 8mm and 12T pinion for 10mm shaft. (4.9:1 and 3.7:1 ratio respectively) – 160€
This was my previous mountainboard setup. The POM wheel gears are the new, thicker, sturdier design. I can’t part this out because getting the clamps on the trucks takes a lot of hammering. If you can ignore the rusted look then this is fantastic value for a mtb drivetrain.
3dservisas waterproof Stormcore/Unity ESC box – 80€
Evolve GT/GTX belt drive guards from BoardBumpers – Free
Torqueboards 75kv direct drives with Radium steel hanger. Kegel and Abec adapters. 100€
One motor has a bit of a resistance due it likely due to a bad bearing. Under no load it uses like 3A of current, and runs 10 degrees hotter. Selling these because they both get stupid hot during chill riding.
Black 90mm Popocal 78A wheels with kegel core – 60€
VX1 without receiver – 10€
Receiver is faulty I’m pretty sure. Or worst case remote is faulty but receiver works XD If it’s the other way round I’ll just refund you.
180kv 6880 Bioboards branded Maytech motors with 10mm shaft and 5.5mm bullets – 140€ for both
More details
Robogotchi without GPS module – 60€
Missing pic cuz it’s in a board at the moment.
Daly 10s BMS – 10€
Bestech 12s 80A discharge BMS with e-switch – 10€
Cut off from a dead battery.
Moon drives with steel straight cut gears with clamps for Luna/Apex air. 59:11 ratio, 8mm shaft. 240€
I think these are batch 7, maybe 8? These are missing a single wheel gear because I had to offer @Rudi a replacement. He has one coming in the mail, so when these sell they will have all parts present.
Trampa VESC mk 4 – 150€
Refurbished I believe, works perfectly. This one can be used with an on/off switch, or wires shortened like in the picture for roll-to-start and auto off
2x Maker X Mini FOC – 50€ each
Maker X Mini FOC+ – 70€
I need to keep one of these for my shortboard, so once 2 are bought they will be unlisted
Robogotchi with GPS module – 110€
Luna 290mm hangers with 10mm axles + black Idea 113mm motor mounts. 400€
These are raked precision hangers, slightly narrower than the usual Moon ones which are 320mm in length, axles excluding. The axles are also slightly narrower. (For example, you can’t fit jump drives + rockstars on this setup. You could with Hoyt wheels though.) I’ve been wanting to use these on multiple setups, but every time my plans end up changing last minute, so they’re still sitting unused. Since they’re RKPs they are ever so slightly too narrow for 6" wheels on wide decks, so I would recommend using these with smaller wheels / a narrow deck. Also the hangers are b-grade, so expect a few dings you’ll never notice after the first ride anyway.
Landyachtz 40" Switchblade deck – 140€
Griptape is in the condition as shown in the pictures. Bottom has some M5 (aluminum I think) inserts which work with Eboosted’s enclosure for it.
3ds mini urethane helical drives 2.6:1 ratio, 8mm shaft. – 40€
These are beat to shit and need the bolts replaced. I’d recommend using wheels larger than 100mm with them. Gears are also a bit damaged due to stuff coming loose, but they still ran fine until I broke one of my motors.
Stormcore 60D+ – 300€ each
One is new, one is lighly used. Selling only because of Radium motor compatibility. Theoretically I have 4 total if you have some crazy project that needs that many xd
Mini remotes, APS remote, Nano X remote – 5€ each
16s 5A YZpower charger – 40€
Daly 16s BMS – 20€
Look how small this one is!
Lightly used Boardnamics 220mm hanger – 30€
VX1 Pro – 35€
Used twice, selling because I got a disconnect once.
Tamron 70-300mm F4.5 - F6.3 zoom lens – 270€
For Sony E-mount, full frame. Used. Perfect condition optically.
Samyang 45mm F1.8 lens – 150€
Samyang 24mm F2.8 lens – 100€
Sony a7 mk2 – 400€
Comes with 2 spare batteries and charger.
If you really are interested in the camera, then I must warn you that:
- The lens connector pin assembly was replaced because my lenses would lose contact sometimes, now the issue is gone
- The screen cable was replaced because I broke it once accidentally lol. no issues there though
- The camera very rarely (once a month I would say) will give a popup message saying “camera error”. Turning the camera off and on again fixes the issue. Not entirely sure what the cause is, but unless you’re doing intense street photography, it’s a non issue.
- Since I did disassemble it a few times for repairs, I have a bag of spare / missing screws for the camera, lol.
