That’s awesome !! The teasing is intense,… release the form
!! hahaa
Now I don’t know witch one choose
!! hahaa
Here you go guys:
I will contact you regarding the payment when I’m ready to ship your order. I currently have 25 pcs that I should be able to ship on Monday. I’ll be able to make more in 2-3 weeks time.
Great.
BTW: “By default, 80 cm wire will be provided. If you need a different length please tick the checkbox below and specify the length in the description.”
I forgot about that. I had ticked the option, but forgot to write the length into the notes.
So remind us again if we haven’t been following closely for the last year, what are the software needs?
Does this work with standard Ackmaniac 3.103 firmware?
Done! Sooo excited hehe
Just hopped in for one to use on my new build
Yeeeewwwww! Cant wait!
done…wonder if i should order two
Ordered 2 (in 2 separate forms) !!!
Yup, it does.
Just linking the two threads
Is this waterproof or water resistant, or both?
I’d say splash proof. If you plan the use it in the heavy rain I would suggest that you disassemble it and make sure water cannot get in the housing through the protective glass or the buttons. It shouldn’t but I’m not going to test it.
You will also want to put a thin gasket between the housing and the baseplate.
If mounted on a drop-through deck, you will need to somehow seal the bottom. I believe that could be done with a simple 3D printed part in the shape of the baseplate.
And I’m in!
I wish I had a dollar for everyone who ticks “I need a custom cable length” and doesn’t specify the length.
I’m not sure if I’d need one. I’m looking to use it on a 40" Evo with a unity.
Does anyone know if the vesc from TorqueBoards is a 7 pin VESC-4/Unity type?
Otherwise, I’m in already ![]()
I forgot to add the cable length in the notes.
