We will now stock the latest version of reacher 6495 motor, pre oder with a reduced price!
Of cource with our great sensor connector with vesc side for it inluded!
10mm shaft 27mm long so usally no need to cut the shaft for geardrives!
Perfect KV for most boards, 145!
We now have our new baseplates in stock with intergrated tunnel riser (to hopefully satisfy @glyphiks ) And thanks to @RipTideSports for the original design of the tunnel riser!
We got the reacher 6495 in stock now, thanks for the pre-orders! Perfect if you want a nice connector solution, high performance and will use it for geardrive ( 27mm shaft so fit most without cutting it) and 10mm shaft. 145kv.
