I found the same thing in my tests here. I ended up using HFI gain set to 0.100 and it solved that issue completely (trampa hardware, and stormcore 60d+). The stormcore made an audible whine when using sHFI, and the trampa esc was nearly silent other than a loud click when sHFI engaged.
I’m considering using the BioX for my next 4wd build to avoid using sensors and sensor extensions.
What did you find the noise like on the BioX when using sHFI?
There’s literally no stuttering in that video. It’s smooth AF. The only thing I hear besides the “click” at throttle engagement is the smart reverse bearings/gear noise.
Literally at 8 seconds lmao - it is smart reverse though
Good to know theres something other than trampa that can basically achieve silent hfi, although I think it would still be hard to trust a spintend based esc after how many I’ve seen burned up
One local rider runs his at like 160 motor amps per side on 16s, it’s ridiculous, he must have a good one lol
I don’t know what you consider a stutter, but that is normal smart reverse to me. There is zero cogging there. It’s just as smooth as smart reverse with hall sensors. Just the normal smart reverse noise.
I remember not long ago everyone was pretty scared riding 12s boards bc of lack of vesc that can handle the voltage.
Nowadays 18s seems standard in here lmao
