Ah not yet, just apk for now
Any exclusive/ purpose built features or just a UI redesign?
Mostly ui but the main thing is when connect you can choose the board you have and have all settings and mode pre set for that board.
Thatās cool - can you set up entirely custom boards? I have metr in my street and mountainboard
I think itās more the app has all their models
Pre loaded into it
Yes you can choose custom and do the motor and battery settings and add your own modes just like normal metr if you have a DIY board and want to use the app.
Ooh okay gotcha.
Yeah the only way I know to switch is by selecting the bluetooth module in the settings, and it feels slightly unelegant when you compare it to this more streamlined solution.
Is there any way to customize the board graphic?
The new Bioboards app is here, works on any board with metr module because the app is based on metr. Just choose other on board selection. Please share any feedback to info@bioboards.se if you try it. Thanks @rpasichnyk for a great job ![]()
Running a BioX, original firmware that came with unit.
14/67 gear drives
Davega FW 5.05
16S
190KV
175mm
RAMM calculator puts unloaded top speed at 46mph.
eskate calculator puts it at 48mph.
On the bench the VESC RT data is displaying 42mph top speed.
Any guesses as to why this is lower than the calculators?
Took it for a test ride and RIDE GPS says I went 34.8mph while the Davega says 37mph. I know there is always a discrepancy between GPS and Davegas but that made me start looking at bench speeds.
Just wanting to see if my speeds are accurate⦠I have a friend with a speed radar gun so might try that next.
A couple of factors:
- VESC max duty cycle is 95%
- If you have duty cycle current limit start set, then your ESC will lower the current before it reaches max duty cycle, so your steady-state might only be at 90% duty cycle
- Your battery wonāt be outputting full voltage under load. Iām actually not certain if vesc 100% duty cycle is based on theoretical battery voltage, or the actual one.
- Motor KV can often vary quite a bit compared to the advertised values.
- Your tire diameter shrinks when you step on the board and the wheels are squished
- resistance (rolling, wind, gravity, etc)
Thatās if your battery / ESC power is the bottleneck. But true, could well be at high speeds
So I guess my main question is āIs the displayed mph on the davega/vesc RT, my actual speed?ā
Im fine with it not hitting the top speed estimated by the calculators but would like an accurate number from the vesc.
I would trust the Davega more than the GPS data, thatās for sure. Maybe set the wheel diameter a tad bid lower than advertised and it should be pretty accurate.
My neighbor also has a radar gun so Im gonna see what that says on a fly by lol
Hello! Can anyone confirm if the Bioboards heatsink works for ubox v1? Iām not sure if the holes are compatible.
Seems like it does, says Ubox
Yes it does.
BioX is now available for pre order thanks for confirmed delivery date:
Recommended to use with our heatsink:
