The markings indicate the measured distance between the two center points. This is what I believe to be the center distance between the motor pulley and the wheel pulley. 36T/16T 5MM gives 298 Mm belt size. Since my belt is 275 mm, this never fit to begin with , or at least not with the gear ratio
My charger from Bkb had the black soldered to positive and red to negative on the pcb for some reason… Worked fine on until I switched out the charge port. Didn’t realize this until I plugged the charger in
Hello, I attached a video showing my issue with the Uni1 V2 paired with the UBOX V2. Acceleration is not consistent and if I push for full throttle sometimes it does not give throttle whatsoever. Brakes work completely fine. I have previously used this motor controller with a VX2 with no issue. So far I have went through the exact pairing process that Spintend shown in their video and even re-flashed my motor controller to start from fresh still with issue. I also looked in the data analysis and the wheel is detecting the position just fine if I give say 85 percent it registers on the vesc tool that I am giving 85. The remote firmware is 1.02 and I am using Spintends 5.03 firmware for the UBOX. I also tried binding it with the receiver that came with the Uni1 instead of the built in receiver still with the same effect. Any people have similar issue?
Neat! might do that in the future. I want it up and running as soon as possible. It has been too long in the making! Ordered a motor pulley 15T and a 36T wheel pulley along with a 295 mm belt. Also 4 larger wheels.
I wish I knew about the OOP before I started a few years ago haha. I have learned a lot though. Even though I got it in a mixed order, I will get it done. Next up is the helmet but then I should just need to program the vesc and plug the connectors of the system in and it should work. The pulley kit I bought came with a belt of my choosing so if it doesn’t fit, it’s not a big deal as you said I can get them cheaply
If you have a belt that doesn’t fit or a broken belt, you can slice it lengthwise in half and use it to find the size of the belt you need. On the first try, with no mistakes or math.
u need an idler in the middle to make it work, usually u find the “perfect” belt length, then u +5mm to account for the idler placement. when u install the pulleys, the belt will be loose, and u need to use the idler to adjust the belt tension
Ah, so the function of the idler (the ball bearing) is to adjust the belt tension? What if the belt is tensioned enough when it is attached? or can that never be the case, because I wouldn’t be able to attach it without it being loose enough that it can fall off? I think I see how this is used
u need the belt to not skip once when u hard accelerate / brake, if u can have such a belt with ur ratio, then in theory, it should work without an idler
So, this requires an idler because the mount is long? Shorter mounts would not need this? Or perhaps uses another tightening mechanism like moving a piece of the mount to or away from the wheel pulley to loosen or tighten?
Anyway, I think I should get an idler since that’s the type of mount I got. I didn’t get one with my mount
And out of curiousity, you guys prefer not to use them because it’s more work than necessary?
Non idler mounts allow you to slide the motor to adjust belt tension. With an idler mount, you use the idler to adjust tension. Tension is super important.
not because the mount is long, but because there is no adjustment on the motor screws, for example, BN motor mount had the slot u can slide the motor back and forth so u don’t need an idler
I’m only one person that prefers not to use them, but for me they are additional failure points, they make it more difficult to select belt sizes, it’s more weight, and I haven’t seen much better results using them.
