3D printables for esk8
Been working on a riser for matrix 3 trucks and a big one at that as im using the them on a LSSS deck with the double deep under slung enclosure. Ill put it on thingaverse when its done but I wanted to share some progress pics as i go through revisions
Integrates some motorcycle lights and a button in the latest iteration
Another Shredlight mount I made for the bullbars on the AceDeck Z1
Folks got any tips for printing these bigger wheel pulleys? And is it a bad idea re failures, safety, etc.? Keen to try some different gear ratios but don’t want to fork out heaps on pulleys just testing
Yes correctly printed pulleys work great. I’ve been running some I printed with ASA for a while now and they seem to have good wear characteristics. ASA is a pain to print. ABS is a bit friendlier. I might try that next.
Some Newbee Triplelinks tunnel risers I threw together quick. Step files included so you can have your dirty way with them.
Figured someone in this thread could be knowledgeable about this, so crossposted :arrow_up: here.
looks like @abusfullofnuns has a few decks on hand. Maybe ask him to "scan it with an iPhone’s Lidar feature?
Ah true, that’s another option. I’ll look into it
Just tuned my ledlenser head light for go pro interface.
3D here:
https://www.printables.com/cs/model/725032-ledlenser-mh3-mount-with-go-pro-interface
Anyone make fenders that attach to evolve style mounting for 6-8 inch tires?
Uploaded some files for Newbee 4GS drive spacers to go between hub and MBS drive adapter plate in case you have tires that hang over the hub enough to rub on the drive (9" MBS tires, etc.)
https://www.printables.com/model/804155-newbee-4gs-2024-mbs-wheel-adapter-spacers
I designed this Pulley, works with Kegel core and uses a 608zz flanged bearing you can buy on amazon to support the bearing from belt tension. Fyi you need longer truck axles like the TB 218 or evolve trucks. Been gone since 2019 but its nice to be back.
MBS rockstar II pro XL 3D printed wideners
Don’t know if it’s of any use to anyone here but I modeled the shock pad for the Acedeck NYX Z3 gear drives (Element 4.0 gear drive)
https://www.printables.com/model/882049-acedeck-nyx-z3-gear-drive-shock-pad
For the guys running Lipos I Just designed a Lipo Alarm Caddy that angles the pins up for a bit easier of a pluggin experience!
Nice! Do you have a link for the sensor wire grip too?
Is This what you meant? I have a bunch of these on all my batteries
Yeah thats what I meant, sorry.
Yes, exactly that. Thank you!
I’m just gonna leave this here.
text → cad ? wtf… since when?
i wonder what transformer they use?
