3D printables for esk8
Copying my own post here but here are STL’s for the inside trigger spring lever for the Zmote. M2 and M3 screw versions
Does anyone happen to have a file for a helmet shredlight mount? Preferably the TSG Pass but I’m sure most would work. Wanted to try and print something for a night ride tonight if possible.
EDIT: Nevermind, found @Mikenopolis file on Thingiverse for the curved mount… just what I was looking for. Thanks Mike!
Let me know if it works for TSG. I made it for a DOT helmet so curvature might not work the same. I can post a more or less curved one if needed.
Found spots on the sides of the helmet where it seemed to match pretty good.
My solution of helmet light Printables
I’m making a stand for the wheels to rest on in order to keep it off the motor mounts.
Prints in 3 pieces.
Would have never guessed PETG layer lines could be this abrasive
Footstop to optimize ergonomics of the Acedeck NYX Z1 Street. The Footstop will be mounted to the ESC by using the two inner screws of the ESC housing.
that looks pretty good. :+1:
I have one I made for the pass lmk if you’re still looking.
Is it different than the one above? If you have the file I’ll definitely give it a whirl. Can’t hurt to try both. Was thinking about making a mount for the rear to stick one of the SL-FX+ on
Slightly different but more or less the same. I think I put more curve into it. When I’m at a computer I’ll share.
For some reason I can’t find it :confused:
I don’t see this having been discussed yet here, so apologies if this is old news for many but I stumbled across this:
Would this be a worthwhile addition to the wiki here?
I recognize it would be hard to do in a way that fits the proper format but it certainly seems like a useful addition to that resource.
Nothing fancy, but here are a couple risers for Newbee Triplelinks. One is solid, the other has a cutout for a Davega cable.
https://www.printables.com/model/683002-newbee-triplelinks-riser
Those little jumper wires are available all over the place, I have hundreds laying around. Never thought to make a housing for them, I usually just cram them into pins and hot glue.
This is great! Good find, maybe I didn’t look hard enough. :+1:
I’m always digging around my purse looking for the dang shredlights. Fed up, drew up and posted a few simple organizers.
Great idea, especially while charging on one of those 4-banger USB-C cable things.
