I wonder
if I can use this to remake the avio wheel gears
You get ChatGPT to spit out gcode for an 3d printer and I assume parametric cad scripting code.
so programatically drawing the result of generation, neato ! i wonder if it would be faster with a local 7B and acceleration?
// Define the parameters for the gear
module herringbone_gear(teeth, module_size, thickness, helical_angle) {
difference() {
union() {
rotate([0, 0, 0])
gear(teeth = teeth, module = module_size, width = thickness, helix_angle = helical_angle);
rotate([0, 0, 180])
gear(teeth = teeth, module = module_size, width = thickness, helix_angle = -helical_angle);
// Create a hole for the shaft
cylinder(d = 8, h = thickness, center = true);
// Parameters for the gear
teeth = 20; // Number of teeth
module_size = 2; // Module size (pitch diameter / teeth)
thickness = 10; // Gear thickness
helical_angle = 15; // Helical angle in degrees
// Create the herringbone gear
herringbone_gear(teeth, module_size, thickness, helical_angle);
I freaking love gpt4 omg I’m gonna pay jlcpcb so much to get these made
inference time for this?
if you share the prompt i can run it local and compare the times against fine tune
i guess you can battle the models at chatlmsys. It would be cool to see more multi modal
Maybe 10-20 secs
I was *accessing this model on my phone.
They do have a desk top app. The prompt that made that last shape is in the picture above. That prompt was refined by chaptgpt Omni after uploading a few pics to it.
"herringbone gear should be made of white plastic, have 40 teeth, an outer diameter of 40 mm, a helical angle of 15 degrees, a thickness of 10 mm, and a center bore diameter of 8 mm. The meshing pinion should
be made of metal, have 12 teeth, an outer diameter of 12 mm, a helical angle of 15 degrees, a thickness of 10 mm, and a center bore diameter of 5 mm. Ensure proper meshing between the gear and pinion with the specifed ratio of 12 teeth on the pinion to 40 teeth on the gear. Include mounting holes and necessary features for securing the gear and pinion to their respective”
TBH, this is all very very silly. Someone here has to have a set to provide basic measurements. Are you all trying to make both gears? Use whatever tooth profile you want. If trying to match a pinion, It’s significantly more involved.
Welp, I’m officially better at doing other people’s projects than my own. I’m reporting myself.
Follow up derail material in a post like “An AI made this esk8”.
Revisted This Project… “LIPO ALARM CADDY”
Designed to make your use of lipos a little easier, Now with a improved look.
LIPO ALARM CADDY FINAL!.STL (5.2 KB)
“Hoyt Puck Receiver box”
Utilizes x4 M3 Screws For Lid assembly
I advise hot Gluing the wire through hole to prevent debris from entering the enclosure.
HOYT PUCK RECEIVER BOX LID.STL (35.8 KB)
PUCK RECIEVER BODY FINAL.STL (33.5 KB)
Acedeck NYX 3 Truck Dampener
As if these Trucks weren’t soft Enough lol
Printed out of Flexfill Filamentum 98A
Acedeck NYX 3 Riserpad (1).STL (38.9 KB)
Does anybody have 72t pulleys that would work for MBs plastic rockstar 2s? And what screws I need? Thanks.
i have 72t mbs pulleys sitting in a bin. bought them at esk8con but never used em. $35 and they’re yours.
“Rockstar II / RockStar Pro / RockStar Pro II Hubs use M4 X 60mm Mounting Screws” -MBoards
Thanks for the offer, I think I’m going g to try printing my own. If that doesn’t work, I’ll hit you up. Thanks
There are a few on thingiverse
That’s what I’ve seen, I’m planning on printing this one, I hope the creator is not lying about it being compatible with plastic rockstar 2s
does someone have autodesk inventor that can save those and an STL, STP, or 3mf and can put it in here because he only has inventor files on the Thingiverse site
