Who wants bigger urethane wheels?
until someone start dropping curbs with them :joy:
i’d say using a 28mm bearing seat would work great, since
6001 bearing is 12ID28OD (8mmW)
and
638 bearing is 8ID28OD (9mmW)
but 10mm axle u don’t have much choice except have the bearing seat at 26 or 30mm (exclude 22mm because its shit)
yes, 6001 is 28x12x8
So with a 28mm OD, you can find bearings that will fit 12, 10 and 8mm axles. That’s pretty good!
For 8mm, another option would be to use a spacer and put in a typical 22mm bearing.
YES
I think @RipTideSports was working on something similar in this thread, but an affordable variant for the rest of us mere mortals was a way off iirc:
Not sure if you still need more Yessses, but YES PLEASE!
130 x 8 cp and fit 10mm and are more squishy/comfy than normal thanes. I will buy.
I don’t think there is 10ID28OD bearing
Infinityhub tried that method, some people are having tolerances issue iirc
There is, 16100 is 28OD10ID
https://www.skf.com/de/products/rolling-bearings/ball-bearings/deep-groove-ball-bearings/productid-16100
All Tanuki Wheels use a 28OD8W spacing :slight_smile:
just do standard 8mm axle bearings. We are so niche compared to the rest of the skate industry that if you don’t do this and also sell these wheels to non-esk8 builders you may not have enough viability.
Been using InfinitiHubs since they came out and no tolerance issues here, at least nowhere near as bad as evolve hubs.
sweet, then 28 bearing seat is the best dia to do @fujio001
Definitely in! 28mm bearing seat. Pulleys for them would be no problem.
We thinking MBS or Trampa hole pattern? I would assume we are sticking with 5 bolts
Wait that might not leave much thickness in the urethane, maybe Berg or Hoyt pattern? Only 3 bolts kinda worries me though since it’s a plastic core
Make use with retaining ring to get even pressure
Not sure if bergs pattern is still popular, but we can adopt the hoyt pattern since it’s a newer design?
Hoyt 5" is another pentagon pattern, I think that might be the move
then someone is gonna use hoyt rim on jump drive if it hasn’t happen already :joy:
For ungodly levels of torque? You know you can fit 72T pullies on 125mm wheels right :grin:
My vote would be a press fit type like kegal or abec, ish. With a bearing in the pulley. Could also use BN m1 streets.
72T pulleys are 113.4mm outside diameter. Belt would be 3mm from the ground, lol
