One of my favourite builds from 2017 was a single motor
https://www.instagram.com/p/BZGP4DZlgKs/?igshid=az0sqs3qzwip
5x 2s Lipos 192kv motor 1.6 focbox
This board used to look for Hills to climb
My board I like the most is similar, 10S 190Kv FOCBOX 1.6, despite dual drives sitting right next to it. It will eat any hill around here.
A single 6374 or dual 6355 is pretty decent, single for weight savings and dual for better brakes.
Dual 6374 puts a wide grin on my face every time but is quite heavy.
As for the vescs, I found that things start to go from meh to fun at around 2500W so get something that can handle that and you’re good to go
Thanks for the feedback so far guys! I don’t know what HFI is, so I guess I should look into that. And I’m leaning towards a sensorless dual 6374 setup just to be on the safe side.
But I see that no one wanted to reply to my question about Mboards
I don’t want to start any drama or anything, I’m just genuinely curious as to why not choose them. Also what’s a good alternative then (favorably without shipping over 30-40 usd)? Can I potentially buy a Meepo battery to use in my diy? Are those just plug and play or do I need a extra BMS or anything like that?
MBoards batteries have been of questionable build quality and overpriced (based on the quality you get), there are a lot of better alternatives.
I would get a meepo battery before a MBoards battery, but better yet get a custom battery from someone on the forum. Also, ask @kook about MBoards, he has some strong opinions about them.
Get the best battery you can afford, there is a lot of energy stored in our packs, and the potential for fire or injury is very real if the battery is not built properly.
Check out these threads, there are a few people missing from the wiki that make very nice batteries, you can check what people have made in the other thread:
@b264 Hey brian, what max battery amps are more realistic? I’ve killed some escs and maybe that’s what i’m doing wrong
It’s really common in my opinion to get the idea that you need to set “battery max” really high to fit in with the “cool kids” who build one million dollar boards that may or may not break down all the time.
But lowering that to a reasonable level is the quickest way to make your board more reliable. On a single drive, 30A battery max is plenty, and on a dual drive, 20A+20A is plenty. You will get tons of performance from that without overdriving all your parts and being plagued by failures. Save that drama for the folks who are chasing that.
Also don’t confuse “battery max” with “motor max”. Motor max should be high. Like 60A to 110A (-ish) depending on the motor… regardless of your battery max setting.
Brian is also the oldest guy on the block take that for what it’s worth.
I’m out skating while you’re still working on boards at home though
I like picking rocks and frying stuff. its peaceful and exiting you need that mix in your life, or you get old and boring.
to be fair I am searching for any topics about Mboards battery packs or pics inside and I got nothing.
I can help you out with a battery if you are still in need.
I was replying to @2rill
