Wanted items cheap or free
I just looked at mine again and was wrong… I had the 1020 and that was a squeeze so yeah a 1040 should be good… U have to pull out the rubber liner BUT I cut the rim of it off so you till have a water tight seal when you snap the lid closed… I dont really need to rebuild yet but was.contemplating ordering the 1040 amd 1050 at the same time and then returning which ever one I didnt need…
Okay that’s more reassuring, if the 1020 works I should definitely be fine with the 1040
yeah 1020 def a no go for anything other than a unity if a dual… Single… Ok 1020 will work.
Any good also
images
anyone got a spare aluminum heatsink for a chinese dual ESC? 100mm x 80mm
looking for the following parts if anyone is tryna get rid of them:
  • Chinese ESC enclosure
  • RipTide bushings new (if anyone has an extra set)
  • 3 pairs of XT-60 connectors
Go check @Scepterr thread RIGHT NOW!
I’ve listed some of these
Anybody got extra 8P NESE tabs? Thought I’d ask here before I buy direct
Wondering if anyone has 8pin jwpf connectors (like so:)
Or if you know where to get them cheap/fast…
Otherwise I’ll have to replace the other end with m8 connectors that aren’t as nice.
Does anyone have a 72 tooth pulley that would fit fivestar hubs? (US)
Kinda hard to beat $20 new, straight from the source.
You’ll need 65mm bolts bc fivestars are wider than rock stars. Try calling MBS to see if they can include them. Last I knew they were trying to get them on hand.
I really need a 12S charger if for whatever reason someone has one to get rid of.
If not just going to get a $50 one from Amazon.
How many amps you need? I got a 2A one I’m not using
2A would be ok
i’ll pm you
Looking for 2x 6374 sensor board.
Would those be diffrent from 6355 sensor boards?
you can have my 12s charger for free if you buy my 12s4p battery :joy:
looking for some fuses like these for charging ports
https://www.mouser.com/ProductDetail/576-099707.5WXN
@b264?
Anyone got some cheap 90mm abec clone?
I’m looking for mtb straps like those mbs too.
Located in France :slightly_smiling_face:
