Did you pre load that helped me a lot in front
I’ve barely played with preload. How many turns / mm are you preloading the front?
I’m at work I can’t really explain @glyphiks or @Venom121212 can you explain this cause I will totally throw him off
Pre-loading matrix twos
Shoot me a dm with address. Pay shipping. I’m like 95% sure I have like 8 oranges
You’d actually get less stability with softer bushings in the rear, especially since you will have created essentially a symmetric setup. I’d try the preload first, possibly even in the rear as well as the front.
Although don’t forget to blue loctite those retaining screws. One worked itself loose while riding and the bushing fell out during a turn.
I just noticed the gap text:
1/4" (3mm) gap between shock and truck hanger surface
except 0.25" is 6.35mm
interesting tolerances we got here lol
That was on the back of a poster I got from them haha.
I’d go with my recommendation.
I just keep the front tightened just enough to eliminate slop and the back just a tiny bit more ![]()
Anyone have a FS 6374 rotor in usable condition in their junk drawer? Need just the can/rotor/bell half.
Have monies. Will pay.
([WTB] Flipsky 6374 Motor Rotor / Can / Bell / Housing only)
Thanks
If you’re in Ohio I have a bomb of a battery that may be salvageable with a bit of work. Zero liability on my end tho, you burn down your house & it’s on you ![]()
I have a couple spare FS 6384 if those are okay, in a couple different kv
U still need battery
Looking for a pair of jst zh 1.5mm 6 pin connectors. Just need two. Thanks.
Anyone have the wire to go to a METR CAN?
2 x cheap focer
1 of them the usb port doesn’t seem to be working, 1 of them won’t detect motors.
No idea what is wrong with them or if they are fixable, but they are brand new, never used.
Pay postage from Aus and they’re yours.
Edit: SOLD
Im.using m6 and they hold up very strong. No problem for years
I need some bolt on kegel pulleys if anyone has some lying around
Why specifically Bolt-on?
