cool, yeh chuck us the model number whenever you can, thanks
First item in post. 80amp discharge
Thanks,
itâs overkill for what I need,
going to order a couple of the D140 as theyâre smaller and Iâll have a spare for when I mess the first one upâŚ
Bump ![]()
yeah its a machine if you want that added security for discharge and pushing sum amps
remember, iâm also taking recommendations
How in actual fuk do you have a link to everything for a great price? I bet you have a folder on you computer full of links to products
nah ebay always is the place for low quantity cheap bolts
Anyone got some 10mm bearings for 10mm axels? Thanks guys
MG Chemicals #4228, #422B, #419D, and #419C (if you can find it)
Plus some neutral-cure silicone
All you ever need
Sending you a PM
need to know outer diameter of the bearing (inner diameter of the bearing seat in your wheel hub or pulley) and hoe many you need
No name calling
Shesh same outer as a normal skate bearing. And like 4 maybe
Look up 6900ZZ bearings then
or 6900-2RS
or 6900RS
Anyone know the bearings that fit dickyho AT hubs? It looks like they fit standard bearings but theyâre just slightly too small
nah they are bigger
if you give me 5 min i will check mine
Thanks Shua
628 i think
8 by 24 by 8
