Get good
Aight I’ll just bore a 84mm hole in my 110s and put them over my Cags just for you
Finally some real innovation
10 degree baseplates would get you close to ultraboard status
I have 18mm of ground clearance as is, I can’t afford to give up another 13mm ![]()
BOTY voting is now open! There’s a hundred reasons why you should vote for Orbital, but obviously, chief among them is that it’s a beautiful, slim, sexy ultraboard! In fact, with a show stopping 280 mm of deck clearance while inverted, it’s the most “Ultra” board that has ever been built. Coming in at a slender 500 mm thick and weighing only 28 kg more than a feather, it’s clear which build you should cast your ballot for. Get out the vote!
Manta Pro. It’s discontinued, but the board is for sale now.
thread neucromancing ritual
I dunno man those bindings are pretty tall ![]()
Yeah the bindings disqualify it. But if the bindings werent there, you could roll it over end to end and only wheels touch the ground
Everyone knows bindings and davegas don’t count when it comes to ultraboard qualifiation ![]()
What about the baseplates? Highest point on my dual hub is the trucks, top of the standing platform is below the top of the wheel
Can you ride the board without the baseplates? You gotta count them into the look then I’m afraid. (It is close though and looks good I gotta admit)
Aww damn, well I’ll always think of it as a special achievement…standing platform under 85mm off the ground is not easy ![]()
Pics or it didn’t happen
I will get those in a bit ![]()
Completely forgot but here it is, entire standing platform well below the top of the wheels, metal yard stick as height reference
Center of the board measures a mere 47mm thick apparently
This ultra board label should come with levels of ultra. And that should be a function of the wheel size. the smaller the wheel. the moar ultra.
Someone fully understands. But most things in this thread don’t even fit the definition at all. ![]()
Temporary but ultra
