Yeah I could. But this is a esk8 forum
All I can say is, that this is so much more fun at the moment, than my trampa boards.
Me and a friend, both have trampa boards , comming from the esk8 World, the vesc was the obvius choice. So my friend bought the vesc 75/300. All I can say is, that vesc is not ready for bigger motors yet. We had so much trouble with no power, and wrong detections. In the end the vesc gave the magic smoke. Now we both run a sinwave votol controller, with field weakening. This is night and day, we have so much more power now. You can se my friends gokart here, running his old setup with the vesc75 and the DAVEega fucking up (because of vesc75), it did only 50kmh.
Yes sire⌠Killer deal⌠Thats why I went with them in the first place. They are used cells though⌠But they are big (because of the greate C rating) So I do not have space for more that 2p (16 amp) Thats why im looking at li-po´s at the moment, which have a more compact design (density) Maybe they do not have the same good C rating and lifetime, but if I could do a 2p setup with these it would help, and would bring the amp draw down on the single packs.
Vesc canât do field weakening. I gain like 25% more speed when using field weakening. And the vesc fw do not detect big motors very well. At the moment I would not use vesc for other than esk8 and ebike wheels.
My fingers is crossd for a 100v field weakening vesc some day
Its been on the to-do list for quite some time tho, think its started but not finnished. Been awhile since I spoke to Ben now @Trampa might know more.
Problem is mostly that motors >10kW are crazy expensive so not alot have been tried. So far Ben has run it on a hand full of big ones, noone which seemed to fail(from what I know). So maybe report what motors is causing your problem
The VESCâs L and & R measurements are completely off from what my LCR measures, maybe that has something to do with it? FOC should theoretically scale up to any sized motor, so long as the P and I gain are adjusted accordingly for the measured L & R.
Also, field weakening is impossible for a PMSM, since well, the field is created by permanent magnets.
Filed weakening has been done on VESCs and we will probably see a menu bar for that in the near future.
Big motor detection is not an issue. You may not want to use the wizard though. Vedder will ad a bigger motor to the wizard soon.
Maybe just by a factor. The VESC might measure only one phase and not across all phases. It depends on the value.
Regarding vesc. The moment we have a 100v vesc with field weakening, and is working reliable for bigger motors (officiel specs off mine is 3000watt and v-slot magnets) I come back
Do you how many cycles you have on yours? My turnigys got the slightest bit puffy on their 2nd or 3rd charge and now its past 50charges I can barely close my enclosure <|:(.
