That makes more sense I guess,
I saw them and I was like,
Well he doesn’t need the length for bigger motors;
Doesn’t need it for deck clearance;
Maybe he had an unlimited supply of 450mm belts?
¡Wadis Et FoURRRR!
But yeah that’s cool that you took matters into your own hands and made what you wanted!
Yeah, belts are actually 395mm. And yes, at a time I was thinking longer mounts looked really cool. So I didn’t mind them being that long. Theory tells you the shorter the mounts the better for belt life and torque trasmision between pulleys. I guess I liked running against the conventional wisdom.
Don’t forget about the maytech 6396 same torque as their 80’s just handle the heat better. If I didn’t have to contend with sand on my rides I would go back to using sk3s, I need to get a set of the new TB6380.
