Okay so I’ve got them for a year and have had some experience I want to share.
First, the rear pulley has no spacer between pulley bearing and inner wheel bearing. This would cause uneven load on that pulley bearing and even lack of support on those two wheel bearings when the axle nut is tightened.
Also, I have had 10 inner tubes dead due to my board setup, roughly 80%(90% maybe) of the weight sits at rear axle and creates lots of heat and load. All 10 dead tubes were on rear wheels. Anyway I found that Torqueboard tubes design could be improved.
As you can see, when torqueboard tube is installed on the wheel, the valve design and angle forces the tube to twist and puts load and wear when riding.
6 out of 10 of my dead tubes worn through the same spot due to this twist effect.
Have tried that and even proper pushbike tube repair set. Found that these small tubes are throw away when they’re damaged. Don’t even try patch them, won’t last for 5 mins.
I have one popped already to mess around with, was hoping slime would solve my issues for my a duration of use but from this it seems they may still not.
will try the evolve 150mm tube out I guess, wanted some purple knobbies as well.
I’ve had too many problems with TB stuff to go back there, doesn’t help Dex’s communication is garbage and his whole attitude whenever his products receive criticism is laughable.
