Lol did you just find that channel?
Someone started a thread on it earlier today
My final solution for my big power bank was to just not use 1s.
I went with 6s, and used USB outlets designed for cars and ATVs that can handle up to 24v nominal (28v max) input like these ones:
https://www.amazon.com/Charger-Waterproof-Delivery-Voltmeter-Motorcycle/dp/B07NV9D61R
https://www.amazon.com/Outlet-Charge-Charger-3-Port-Compatible/dp/B08LKZ1H92
The higher voltage means that you get 6x more energy into the pack at a given charge rate - a 1A charger is 25 watts, instead of 4.
Also it means the chargers can output more power - The one I have can do USB-PD and QC3.0 up to like 60 watts or something, so it could charge a laptop or tablet much faster than a 5v-only charger.
I just watched it, love this guyâs videos.
he just LARGELY stepped up the battery building game
also did you seen the apex bms ? hehe
Looks like a generic smart BMS to me - I think I used one just like it from aliexpress a few years ago.
yeah itâs a generic bms but sold by someone on the forum wich is kinda nice to see
True.
Iâm so happy for @Lee_Wright for having the forethought to put his sticker on the BMS before selling them.
not like other builders here do the same
hopefully one day he and others will be able to make their own BMS
Itâs an LLT - we arenât trying to hide it
Thats a great video
Isopropyl alcohol would be fine to clean off cells right?
Try to get a high concentration so you donât have to worry about water rusting anything.
I have 99.9% in a spray bottle, ready to clean any surfaces off. If I touch nickel a lot while cutting it to shape I will wipe them off. If I donât, I can see smoke of skin oils burning off when welding. It also helps cleaning up flux that splatters.
anyone know??
A search should turn up a bunch of recommendations as I remember several people posting with their thoughts on the ones they use.
Cool, good to know.
Iâve got 99.9% on hand already from cleaning computer parts
tried but couldnt really find anything
i seem to remember in the past @skyart recommending some
Found these in a few seconds. They have links, pictures, or a product name to search for.
No looks IT IS thay just buy them and stock then in the uk. Just like 99% of stuff you buy from a shop. Tho the QR code is a idea from a forum member thay incorporated to get the wiring diagrams.
Hey fellas just wanna make sure Iâm correct here before finalizing my bms wiring. The LLT smart bms has 2 each of B- and C- traces. I believe based on the diagram provided by the manufacturer that for a charge only circuit the main neg terminal goes into the bottom B- and then is attached on the other side to the bottom C- (as below) which would then terminate in an xt30 along w the wire from main pos terminal for the charge port to attach to. The other 2 traces are for discharge. Is this correct?
Both terminals are the same, they are directly connected i believe. brb checking with multimeter.
Edit: Yes they are. Doesnât matter where you connect to, upper or lower.
