Is this from the pack you tried to sell a while back?
yep took it apart into p groups but dont need anymore
paid prob 350 for the cells and nickel so not looking for much for it
anything particularly bad you can see? i can see one joint which didnt stick to well which im gonna do again.
Here’s where I landed. Not at all happy with the enclosure depth but hopefully won’t look too terrible.
I think your soldering is not wet enough or hot enough.
Needs more solder and more heat
cheers will do
im assuming i can still add on now?
maybe could you send a close up of what it should look like?
cheers thanks will get them to look more like that.
That almost looks cold you didn’t heat/tin the nickel enouth shouldn’t be balling up we’re it connects to the nickle
See how it flows in to the nickle not mataining surface tension
I tin both sides, then I just added more material on top (it all flowed so a solid connection). It’s easier to get it pretty with smaller wires though
That hole punch technique looking fineeee
You are a genius for that one
Maybe it’s just me but those look like they might be missing a bit of solder.
Also remember to tape up the p-groups you aren’t actively working on so nothing accidentally shorts.
This thread might also give you good ideas of what to aim for your pack to be like
i put a ton of solder on them and it just kept building up on top
the connection is very wet and really tightly bonded
May i ask you regarding a battery i wanna build if this would be ok:
So i wanna make a 16s 4p battery with 27100 cells tht have a discharge current of 45a
When i spot weld the seriel connections with 0.2x20mm nicel strips do you think this would be ok or do i need to add additional copper wires between them?
Thx for your input
- Molicel P42a can only do that much current if you monitor their temperature. 25A, or maybe 30A is probably the max you should be running them at per cell.
- When choosing Nickel, I like to go buy this chart of data gathered experimentally with nickel welded to cells made by some guy on the e-bike forum.
So if you’re building a 4P battery, and expect 25A per cell max when drawing power continuously, you need the series connection to be good for 100A. From this chart we can estimate that 0.2mm x 20mm nickel should be good for about 36A max. So if your series connections are just pure nickel strip, then you should stack 3-4 layers of it.
This is why for high current packs usually people connect the series connections with regular wires or copper braid, and not just nickel.
