Yes this is true. I oversimplified it.
In reality you can charge li ion batteryās with any thing that will vary the ampage and voltage.
Slower is better but there is a point of diminishing returns by the time you get down to 1/2A per cell itās not notisable in the pack life span.
The most important thing is you want to cut the charge off when full itās bad to have li ion been held at 4.2V. Not many charges do this itās more common for the BMS to do this.
In reality I have 2 chargeres I use Often
12A to blast the battery because I want to use my board soon (Iām fully aware that this will reduce the life span of my pack but I also use this for 10-15min not to fully charge my board)
1.7A I leave on over night
If you intend to use it as a comuter to work or collage then calculate a charger that will charge the board a hour befor you want to use it. This will maximise the life of your battery
Iām about to buy myself a proper (Malectrics) welder. Does anyone know how/where I can get cells to ācalibrateā on (or what pulse duration I should go or start with), and what battery I should use? Is any 3s 5AH 60c+ going to be fine? The Spim08hp (I saw recommended by fosterqc here) and lipos recommended on their site donāt seem to be in stock anywhere. Also the cheaper the better
@Skyart is trying this thing too
that is one thicc boi but unfortunately a little too high in price for me
Dope spotwelding pack.
$24 plus shipping for the 6 spim cells then, and $6 for the rest of the materials
Ohhh wait I didnāt even notice the first link lol. Are 3 of those not enough to run the welder for enough time?
3S3P was barely too much so 2P was good for me.
Why do you need to save $12??
2P is lasting a long time.
Iām just wondering if I can save a little bit but its alright
So um my next question is what kind of copper can I use for hooking cells up that peak at those high currents when I weld
is the steel city store on aliexpress a reputable nickel vendor?
I think i heard this store sells pure nickel on this forum
I need some 0.2x50mm and 0.2x30mm nickel
https://www.aliexpress.com/store/3874113?spm=a2g0o.store_home.1000001.12.7a214fb4j8lK77
I believe so; Iām pretty sure people have bought from there with good results
What the hell you planing to use that on a e skate. Triple row or something
Double stack with a fold over
exactly this
also just to have it laying around. Some day Iāll need it for something and then I can use it without waiting a month
Do you need the fold over 50mm 0.2 must be able to Cary 45amp ish. Double it up and no series links needed nickles good for a solid pack
Unless its a brick pack, I think itās a wise idea to build all esk8 batteries with the ability to flex.
Send me a PM i can sell you the lipos I used before I got that BMW battwry.
Is there a smart bms out there that is small ? I have the one that is from ali but its huge and want a chatge only version for my short board build.
