The battery builders club
I would get at least 8A but 12A would work fine for that config.
Do not get a 2.1mm port get something like a XLR, M16, GX16 4-pin or XT60 panel mount, there are many other options out there.
4A charges in 450 minutes aka 7.5 hours.
8A charges in 225 minutes aka 3.75 hours.
12A charges in 150 minutes aka 2.5 hours.
3 hours is the maximum for me personally to charge a board, especially at group rides. With a 12A charger you could stop somewhere for an hour and be 40% charged, that will last you a while at 12s10p.
You can alway grab a lower amp charger to slow charge at home when speed isn’t a concern.
0.5c so 15A for a 10p, I am a big advocate of a panel mount XT60
Are you interested in non-mobile options?
Can do up to 50amps for under $100
@CiscoV
what charger and plug did your Flux come with?
i would like to get a plug that fits the hole that is already in the enclosure.
yeah dude.
I will never lug a charger around…
Sup brother.
Flux came with standard 5.5 barrel plug. Drilled to fit cnlinko m-16 plug
This is the 96v 20amp version but just get the other converter for 60v 50a. Just keep in mind, you can’t get more than 1500w from a standard US socket
These are only rated to 5A. I have charged them at 6A and they get fairly warm. 8A would be pushing it.
I mean, the less amps you are pushing into your cells, the less wear you will create. At 10p and 2A, you are only pushing .2A to each cell. Thats gonna be great for pack health, but very slow to charge from empty.
Pushing fewer amps than that might give you slight benefits to cell health, but there is gonna be a point of diminishing returns.
My suggestion would be to build it, charge it with what you have, and decide if that is fast enough for you. If not, think about a bigger charger. A 40A charging limit is a lot of room to play with (though keep in mind that the limit of your BMS is almost certainly lower than that).
P.s. oh yeah. Slower charging also means that your BMS will have more time to balance your cells. That might also be good.
At some point I just want to have a bunch of chargers or a nice variable charger, then run all 4 of my boards at 12s between 2A and 14A
By getting a 2A, 4A, and 8A charger you can get every even charge current up to 14A by combining them
Very true. Most smart bms can be set to balance from a set level during charge. So essentially you start balancing right when you start charging. A lot of BMS will only start to balance when cells are above 3.7. I’ve got mine set to balance at 3v.
As far as temps go. Well I can charge at 20a, but in order to stay below 40c, I actually charge at 17amps. That’s for a 12s7p pack of qb26800, which are thermally worse than something like a 30q
I’m really hoping to find something ready to go on Amazon…
@CiscoV
What is your 6.5 charger?
Boy.
I like the sound of this.
Using the stuff I have sure sounds great.
Again @CiscoV
What is up with your 4amp charger not charging all the way…
Makes me worry about going 2 amps…
Why is diy sooooooo hard you guys?
Bruh you made like 20 boards, you’re a pro by now
Quantity is very different from quality…
And I am slow and struggle with new concepts :grin:
You got me there :joy:
So called “stock kaly 8a” brick
It only goes up to 6.3a lol
Idk brother. My assumption is my brand new pack was out of balance
Have not checked again since started using my 6.5a charger But again. I’ve cycled the pack a few times since
He also making really great NYC real estate content.
Yes battery’s get hot when charging heat is your enemy. The heat is the limiting factor and what degrades you battery when charging if you can keep the heat down you can almost charge as fast as you want .
If you only going to charge super slow then the censer will only be any use if the battery fails but this could well stop a fire in that case
I strongly advise been very carefully with even trying this most chargeres can not be paralleled up because backfeeeding can brake some chargeres and confuse the CC CV logi circuits resulting in to high voltage been fed in to you battery.
I disagree we use CC-CV to charge so the wattage output by the charger is not consistent you need to add time to ramp up to full wattage and them more time to ramp down and balance. This could add 30min to a few days to the charge time depending on many factors this includes the charger heating up/efficiency
