I made a 12s3p out of those $.99 hg6. Really nice. No sag great short trip pack.
Does anyone have an extra 12s d140?
I would gladly take it
Pics or it didnāt happen
Ha, I actually didnt take pics this time. Third pack so figured i was good on this one. Have to ride some time. Has great torque even with 6355ās and my small body.
Actually yes you can and it works pretty damned well if youāre stuck doing that.
We are using the wrong solder. Apparently you can solder, braze, and weld stainless to copper. A very cool article from a group of guys into DIYāing alcohol in the basement ![]()
@Arzamenable @M.Hboards
https://learntomoonshine.com/how-to-solder-braze-and-weld-stainless-steel-to-copper
How To Solder Stainless Steel To Copper
If you choose to solder your components together a common plumbing solder containing 95% Tin 5% Antimony will do the job just fine. You can also use Lincon Electric Solder Stay-Bright Kit With Flux that is 95% Tin and 5% Silver for better results. Both solders will have a melting point of 230°C /450°F and can be heated with a simple propane or Mapp gas torch. You will need to thoroughly clean both pieces and apply a coating of flux to all surfaces to be soldered.
haha, what, you afraid of a little sparkle sparkle?
A regular soldering iron gets to 450, no problem. A good one more, prolly.
That donkey-kong soldering dildo you have prolly goes to a thousand degrees, lol
A little razzle dazzle? Ok, I see your angle.
doing up that 12s8p as we speak
these used cells that @Dog is selling are actually testing out to have totally decent capacity, if you can live with the sag. Higher p groups required. perfect for a charge n ride.
edit:
Iām getting over 14 amp-hours on the 8p groups from 3.57v to 4.05v
Come take my spotwelder. I donāt work till next PM
Also, I have A second ride and charge enclosure you can have
Which nickel you want to weld with it @Skyart ?
It can weld only nickel which is below 0.12mm and thatās already very thin.
What do you mean? I weld .2 all the time
This one I mean.
Have not ordered yet
What I meant to say is that I donāt understand why you want to buy a spot welder which canāt weld proper nickel.
For science Andy!
Ok ok⦠seems like Iām the only one with limited budget
Nah, youāre not alone. I donāt have money to burn on shit unless I think it holds some sort of value either.
