Dope! Thanks man!
I love those jigs to line everything up!
Better than my crappy wood ones ![]()
Good morning guys. I need some help in putting together a 10s4p pack. I put to get here a few lipo pack b4 but never a 18650 pack. Here is my question. I am putting on the balance cable to my 3d printed pack and I want to put balance #1 cable at the positive tab is that okay. I read that I need to put balance #1 cable between P 1, P2 the connection. Itâs the same right ? Pls refer to the picture.
It depends on the BMS, most will ask for #1 to be positive, #2 to be P1-P2, etc. So for a 10s pack, you will end up with 11 wires. Positive + Negative + 9 in between. Not all BMS, I would look on the schematics of the BMS you are using to see which balance connections it asks for.
I think my bms takes one negative P and 1B-10B negative. P, 1b+, 2b+, 3b+, 4b+, 5b+, 6b+, 7b+, 8b+, 9b+, 10b+
did you end up buying anything from them? Prices are interesting, is it legit?
I hope so, I always like to see someone undercutting IMR.
oh it is the bunk site of the same company as https://www.18650batterystore.com/
so yeah
2.5mm JST-EH
https://www.amazon.com/LATTECH-Female-Connector-Electric-Length/dp/B07Q2JWT4T/ref=mp_s_a_1_7
https://www.amazon.com/ShareGoo-Balance-Charging-Extension-adapter/dp/B078QNS7YL/ref=mp_s_a_1_11
Pretty sure itâs these guys. IIRC itâs smaller than JST-PH 2.54mm
Just measure pin distance, and search on amazon
âXpin JST Connectorâ or â(X-1)S balance connectorâ
I highly recommend just buying a housing and crimp assortment box on Amazon and crimping your own with silicone leads
You got a crimper you can recomend?
I use a version like these just fine
https://www.amazon.com/IWISS-Crimping-AWG28-20-Terminals-Connectors/dp/B078WNZ9FW/ref=mp_s_a_1_4
But these are the GOAT
https://www.amazon.com/Engineers-Precision-Crimping-Pliers-Pa-09/dp/B002AVVO7K/ref=mp_s_a_1_7
Just a heads up tho, if youâre truly stubborn or impatient crimping probably isnât for you. Easy IMO tho.
It is not -PH. bestech uses EH connectors. The pins are both the same for PH and EH (2.5mm) but the shape of the plastic is different.
Yeah I saw the plastic is different
Got the GOAT
Most people bitch about the ratcheting ones.
I just checked my d596. Itâs JST-EH but not 2.54. Either 1.5 or 2.0
I commented a link to a great crimping article a lil bit ago if you look thru my history @skyart
Best bet is to shove a 2.54 up to it or measure the solder points on the back of the PCB.
Huh. Donno. Thatâs my favorite one. They all do the job I suppose. All EH connectors are 2.5mm. Should be anyway.
Can anyone help Brandon out here?
Cant seem to find any 6 pin EH connectors
