Hey guys, I got this smart charge and discharge BMS. However, I am trying to bypass the discharge. I wired up B- to battery negative, C- to charger port negative and charging port positive to battery positive. Then XT90 out to VESCs.
Should be correct right? All voltage added up on each balance lead and whole pack is at 41V (12s), all cells group at 3.49ish voltes.
Once I plug in the charger, the charger just stays green, did I bricked this BMS already? It’s a new pack, haven’t been charged even once lol. Any help would be great! Thank you!
Disregard main discharge lead, because you need to find out of you are getting voltage through the BMS. If not then the charger obviously will not work. You should get full voltage through charging port.
If it’s 12s and it has 13 balance wires then the last one is b- and it should connect to pack -. So the last p group should have two balance leds connected to it. Atleast that’s what my problem was
If you have a bms with a balance jst plug with 13pins but you have only 12 cells in serious it means that your bms needs the b- as balance lead as well and doesn’t get the b- from the B- via bms pcb.
So first cell in your pack had a balance lead on the negativ terminal and on the positive terminal. All other cells have the balance lead just on the positive terminal.
