It doesn’t have a 12s one, but it’s a reasonable assumption since all the others are like this, to think that 12 should be the last connection on the end (17)
It’s much the same as soldering wire but as @ShutterShock mentioned, the solder wants to wick up the braid. You can mitigate this with a set of forceps holding the braid near the joint. That being said, high-strand-count silicone wire is much safer and more robust. If height is a concern, do 3x 16awg or 4 x 18awg instead of 2 x 14awg.
I think w/braid a flat metal bar or metal ruler held down perpendicularly works much better than forceps as a heatsink. Leaves a very cleanly distributed solder joint too. I know somebody on here has pics they often refer to.
I have these 8s1p modules for a 16s1p board (sounds a bit odd but the M100 is a small HV ESC and is the right combination of range and power for me), but I also gave in to temptation and ordered some loaded hubs on here and even 10s speeds on those is more than I need. Would it be feasible to also wire them in parallel when the P groups are split?
So basically 8s1p units where the only shared power wiring are the paralleled positive and negative, but the balance leads are terminated together. I’ve read about p group nickel not carrying an appreciable current between cells in a group and largely just acting as a current collector, and these are new very tightly balanced P45B cells, but I don’t want to accidentally force a couple of amps through a 22awg wire
That’s how i do it. Definitely the best way i have found for braid.
But in general braid is pretty lame. I don’t like it for joints that will see any flex, it’s not fit for that purpose IMO.
Only 2 are recommended most of the time (Kweld or Malectrics) but if you say affordable because you want to save money then you’re barking up the wrong tree. Compare them 2 depends on what you want kweld seems to be better quality and gives more consistent results but others will argue thay prefer Malectrics. People who build mutiple battrys seem to go for kweld or larger more industrial machines. But it cheeper to buy a battry unless you building 1/2 a dozen or more.
Whipped up a little 12s2p yesterday and it’s draining by about 0.2W the whole time, any ideas? It’s been staying balanced so I don’t think it’s a particular cell
Running charge and balance only LLT BMS, battery is in a Meepo V3 enclosure (connected to charge port directly so no charge feedback because 12s and a tap off cells 1 and 11 for battery voltage display)
Hey everyone. I’m looking to buy some .2 x 30mm nickel strip to build a 21700 battery build. Any idea if there is somewhere to buy it within the US, or is my best option something from China like this Link, and hope it’s pure?
