My problems with the malectrics stemmed from too low of current supplied by batteries and surfaces with machining oil remaining on the nickel, can be quickly cleaned with a clean rag damp with 99% iso.
I did wipe this stuff down with alcohol.
it was only 91%.
but I did think of cleaning the surfaces.
since I was able to blast through other nickel I am assuming my 2 batteries are still ok
Wow, there has been quite a discussion about my battery pack, havenāt been here for a while, will have to read it later.
Iām here, I didnāt know my instagram shitposting will be noticed, lmao. Anything you are interested about the pack? I wanted to make build thread for this board, but have been postponing it for a long time.
Nah, there is no need to mark voltages since I always balance all of them to 3.7V. This is capacity measured discharging it from 4.1V to 3.3V at 1.5A rate. These are reused from other packs so I wanted to spread them to a new pack evenly. The white/blue/yellow dot marks the pack it originated from.
Thanks for tagging me
Some cells have the capacity lowered, Iām not sure if the ones marked with yellow dot are genuine, I bought the board here on forum that had all sorts of problems and these cells have lower capacity and higher IR. Or the guy used the board a lot more than he claimed. But the rest are genuine 30Q. Itās not full capacity, itās just way for me to detect bad cells and to compare cells between them.
@infiniteoffset
Cool, cool. Iām glad u got to peruse most of comments here. My battery notation when assembling used cells is nonstandard. Kudos if you checked the capacity of every cell from a batch all from the same donor pack.
I probably would have only checked voltages after a prolonged sit at a balanced voltage for the whole set and removed the outliers that dipped. But that only looks at p groups. (I know, I know.)
For maximum rigor, both capacity and voltage testing of single cells is best.
Donāt take the criticism here the wrong way either. Judging from my past battery instagram posts, I deserve a knock on the door to see if Iām still alive. Itās a demanding group, professional battery builders and testers that sell packs to strangers frequent this thread.
What is the purpose of the PCBs? I donāt really understand how using these would be better or easier than the standard approaches Iāve seen here.
Makes it so you can weld skinnier nickel strips right onto the PCB mainly
They are a bit old now, our methods have evolved somewhat
Realistically they make no sense for the average person, or even builder. They were a stepping stone towards full PCB batteries, like these which have been adopted by a few companies in their production boards.
If youāre building the same battery all day every day, you can use these PCBās to just pump out P groups in a more efficient manner, stack them up and pass them down the production line to move along the process of building a complete board.
Also they look cool. Main reason for me.
You can use narrower nickel strip (<18mm wide) and make connections from the individual cells to the copper bus tracks, and then use wire or braid to make the series connections from one PCB to the next.
Basically if you have wide enough nickel to do the folded-over-tab method, these are obsolete. But if you have a bunch of 12mm nickel (for example) and want to use it up, these can be useful.
Where did you buy this stuff from?
Ali.
January of 2021.
info on link seems pretty murkyā¦
This link isnāt working for me but yeah idk who the go to nickel supply is.
Last time I bought off steel city was about 3 months ago and it tested pure
steel city is solid, but i heard its gone
I bought nickel from 0.2mm * 30mm Pure Nickel Plate Strap Strip Sheets 99.96% pure nickel for Battery electrode electrode Spot Welding Machine|Tool Parts| - AliExpress and it didnāt corrode after scuffing with 150 grit and leaving it in heavily salted water for about 5 days so it should be legit. They do also have 0.2x50mm if you check their store.
Depends on how you collect the energy on the last row.
i didnt build it but the it does not have the rings on it or rounded nickel
For packs that arenāt mobile thatās usually fine. What is that pack going to used for?
a trampa
