Hahaha that’s awesome man. How do you control it? Button on the remote?
Yes with this Bluetooth remote module connected with arduino. The light flashes as soon as you give it a 12v power source. I’ll use the arduino as a gate to control the 12v power to the light using an n channel mosfet (it’s like a switch).
Ohh right I remember seeing that in the earlier post. Holy shit man your board will have more electronics and buttons on the remote than anything I’ve ever seen lmao.
A true tony stark style build. Only thing missing is voice control
Yeah man There is voice feedback with Jarvis’ official voice but not voice input. I actually looked into making my own alexa speaker for this but I dont want to add 4G LTE via a sim card to the board. Without that, its still very complicated. I will basically be building an operating system I have an idea planned for a start up animation for the screen (Boot/loading screen) with my name that I will make in Adobe after effects, which I have no experience with but I found a YT tutorial.
I made this little channel cut out for the turn signal wires. It will go under the davega and wire through a middle hole I will make in the deck for the davega.
Bms tomorrow
got dam shes nearing completion i need to finish off my board already
measure twice, drill once, as they say…
u gots this man ur at the home stretch
God, you’ll need 20" wheels with this enclosure, won’t you?
I wanted 9inch wheels from MBS but they were out of stock. Will probably need a 1inch riser with the wider/lower truck holes and my 8inch tires
My enclosure is probably about 20mm taller than the standard double stack enclosures that everyone uses and I was more than willing to add a proportional riser to compensate for my taller enclosure. Range for daysss
trampa has plenty of 9" and 10" in stock even rn if u really needed a 9" wheel
That will be like a circuit car, you won’t be able to ride on normal conditions. Or a museum piece, just for looks.
My first MBS had 8" tires with a printed bottom enclosure 4 or 5 cm tall. On my first ride I broke it against a rock due to lack of clearance and believe me it was not even close so extreme as that.
Anyway, I hope you prove us wrong. Good luck with it!
I ordered my wheels with my trucks from MBS the extra shipping cost + fees to Canada made me not get 9s from trampa but I did consider it
ahh dam
These are m4s and the hole is m5. It all fits! About to make the holes big enough for the m5 insert.
