As the title says, I am searching for a good, reliable and affordable spot welder.
I would like to order one today or tomorrow, could someone recommend me one? I thought about the Sunkko spot welder, but there are so many different versions that I don´t know which one to choose.
kWeld or malectrics. yes you need a lipo or car battery, but the welds are always solid. with the sunkko and welding pen you might get issues to solder legit nickle strips depending on the model you buy.
You can buy a power supply kit for the kWeld, starts to get a little expensive though
A good thing to remember is that the poor man generally buys twice. Its well worth spending the money i the first place to buy a solid, reliable product
No I dont think the majority use kWeld, but I would say a large number of serious battery builders use it because its such a great unit. I was happy to pay a bit more for a product to know that I could expect a quality result and I wasnt disappointed.
A lot of other builders have tried many and settled with the kWeld. @Acido comes to mind
Thank you SurferofDIrt, So I will get the kWeld, if I get a battery for it which one should I get and how do I recharge the battery and does the level of charge in the battery influence the quality of the welds?
This is the one recommended by kweld, it works fine but heats up rather quickly. I have just bought another one to hook up in parallel to try and mitigate that. But if you take your time its fine.
Perfect I will go for the Kweld then. How long does the lipo battery last and does level of charge of lipo battery affect weld quality and where can I get a charger for the lipo?
Level of charge does not affect the welds… maybe very minimally, but it provides good welds all the way til cutoff.
Its hard to say how many welds it will do because it depends what you are welding and your joule settings. But i reckon you could finish a 10s4p battery with one charge
