https://www.thingiverse.com/thing:4641889/files
Something weird going on with my preview, but the files seem to be available for download.
looks great, its pla petg or abs?
Its PLA time will tell if its strong enough
Any reason you couldn’t run a single motor with both sides of this dual?
it uses 2 MCUs, so syncing them would be a nightmare ending in a fire. Need a stormcore or unity for that.
I see I’m going to have to step up my game.
Also look out with PLA I’ve had issues with it deforming pretty badly in direct sunlight after just a few minutes.
PETG is MUCH more resistant to the elements.
No warping after being left in direct sunlight for hours.
Yes you right PLA tent to deform from 60c I found that out with my vesc 4.12 enclosure when I left my board in my car in hot day PETG would be def better choice but I don’t have any atm so PLA must do it
Any reason not to use both stormcore controllers on one motor?
Might void your warranty + it requires custom FW, but otherwise not that I know of
You can search in the stormcore thread where people were talking about it + there’s a video of Charles demonstrating it working I believe
Hi Guys! I started to build a skateboard from enertion raptor 2.0. (sorry if it a noob question, this will be my first custom board).Two focbox left from that, and my question, if i buy a spintend ubox, can i connect the two single focbox to it, reach 4 wd? There is two canbus on ubox. I asked them in e-mail, and they said, they havent tried it, but 2 uboxes can work together. Should i buy 1 ubox and try it? Is there any possibility it will works? Thanks for reply!
Just putting this here so you know about it
As for the CAN, you probably could do that, but I don’t think anyone has tried it yet. You could always split the PPM signal too
I don’t believe you’re supposed to mix v4 and v6 hardware although that may be a solved problem.
I don’t think so either, maybe the CAN would be funky. Doesn’t matter though for split PPM technically
I’d still be wary since V4 hardware would be at 100% duty cycle at 85% PPM input while V6 hardware would be at ~85% duty cycle, not sure if this is enough to cause problems or even be noticeable but I wouldn’t recommend taking the risk.
That logic does make sense
go go gadget dual-receivers!
