Any updates on the 5.02 firmware?
It’s updated now. please download it from our website
it’s updated in our web.please download it there. thanks
Hi, friends ,the customed 5.2 firmware and source codes are updated in our website.
More of a general VESC question, but any reason to update from 5.01 if we’ve already set the duty cycle limit? I’ve heard there were some CAN issues out the gate on 5.02, so just wanted to make sure it’s stable before switching over and doesn’t end up breaking more stuff.
Is there a way to turn reverse of on the uni1. I dont know how to modify remote settings on the vesc tool and it seems like calibration is done through the remote
Btw, loving the lights and horn option
Well I may have killed my UBOX.
Only the “Vesc A” side lights up when powered on and it’s just throwing a red LED error.
No response to throttle input. I’ve tried everything that I can think of. . any suggestions?
13S battery.
Pop it open and inspect for visual burn marks
Now it’s like both sides are working but side b keeps throwing an error light and temporarily stops functioning.
What happens if you try to re-do setup?
Just what I described above. I actually tried that first.
The first time I ran detection it gave a crazy reading for one motor. It rated one for 40 amps and the other for 68.
Ran detection again and readings seemed normal but now I get the “fault code” light and one side is working intermittently.
What are the fault codes in the VESC tool? Could help pinpoint what’s wrong.
This.
Rebooting the ESC clears them, so look before you do that.
Maybe try flashing the bootloader on the bad side using the good side. @abusfullofnuns was forced to become an expert on this recently.
I powered the board back on after a few minutes and both motors worked on the bench for a few seconds before the left motor stops working and I have a red led in position 1 flashing 6 times then pausing briefly before repeating the 6 flashes.
How should I deteine the fault codes in the vesc tool?
type faults into terminal
Aha! It says fault: over_temp_motor
Bad temperature sensor in the motor?
Edit: it also seems like the motor that is throwing the code has much less torque than the other
if you unplug them then try?
