I wanna get a helmet to hydro dip in carbon fiber to match my board. With a Pearlescent rainbow visor.
What do you guys have?
Demon podium after I split open my triple eight invader.
Demon is lighter and airier without feeling weak.
I would advice against those big sun visors on helmets.
I know of bike accidents where they fell face first off the bike, which wouldnât have led to nothing serious if the visor wasnât there. Sadly though the sun visor caused the head to be thrown back so violently that they ended up with a broken neck.
The visor on my Giro is a breakaway design, the bolts are clutched and pop out on impact. Iâve tested this first-hand (replacements are about $20).
Are the tsg passâs really worth it? Do they scratch easily or not (both visor and helemt).
I am hesitating between the pass and bell 3r.
I have a friend with a 3r and it is really cool but not really in the same class as the tsg.
lol.
3 wtf? What i meant is on the website they look very glossy. Are they just like a normal helmet in terms of material?
Yeah, sure i was thinking much less nvm.
Just a quick question though
Is the buckle magnetic or clip style?
I do find that the TSG doesnât let enough air in/out, so it feels a bit like youâre slowly suffocating unless you open the visor every once in a while. Pretty annoying imo. Also, the visor has a tendency to fog up the first 10 minutes of riding when itâs cold outside.
The Ruroc on the other hand lets in plenty of air, but the visual field is limited due to the chin guard and goggles.
Itâs about protection level and weight. Check tsg protection versus bell 3r.
Tsg- EN 1078 â1078g
Bell 3r- spsc bicycle â 750g
661 Reset: spsc bicycle, EN1078.
det är väldigt dyrt ![]()
For some context (on Deckoz) https://www.electric-skateboard.builders/t/what-protective-gear-do-you-use-excluding-the-helmet/48261/31 <-- Agree with everything Deckoz says here and if you plan to ride fast (anything over say 20mph) then gearing up really is the way to go. Personally just use a basic triple 8 because it was cheap and I was relatively broke when getting into this, but have been eyeballing Ruroc or TSG for a while (still on the fence but I lean towards Ruroc just because of style really, big visor is a bit much to me).
yes, they both areâŚ
