Either that, or the way he rides
I canāt ever imagine having that much motor heat even on a hot summer day, and I am a heavy guy ā a heavy guy that rides a lot of single motor and dual 6355 skates.
Bingo. The man is a straight savage.
I love fireworks, every year on new years eve i make a little show for the street
i donāt have work so only around ā¬200
Once you try the lever door handles
You wonāt ever go back to the round knobs
You can even carry two esk8s and still open the door with your foot if you need toā¦
I just tried. They fit, but they donāt fit well. The pivot cup isnāt quite deep enough on Caliber2 baseplates. But itās ridable.
Iām 74kg (163lbs) ![]()
Yes I have to admit often I like to accelerate as hard as I can and/or ride crazy but this is only possible with Vesc 6. On my jump board with V4.12 there is thermal throttling due to hot Mosfetās much earlier while the motors are just warm. Even with 45A each motor I can ride max. 10-15 minutes in dirt park before the V4 start to overheat.
I get overheating motors on flat terrain. Hill climbing is almost impossible in summer. Usually I ride the MTB early in the morning, late evening or in the night. But it also happened that I had to take a break at 2am in the dark because of too hot motors
On my commuter with dual 6355 I rarely have heat issues in summer but thatās because itās a lame vehicle (in comparison to MTB) where pushing full throttle isnāt scary.
4wd will fix your overheating problems
Isnāt that just a megameter?
can you tell me more about this drive system
the idea is good to get more clearance from the trucks
ho lee fuk
@moon itās been leaked
protocol alpha charlie houston
Absolutely correct
Same problem here.
My vesc 6ās are chilling with 38°C and my motors are at 50-70°C depending on my current ride style.
My motors were triggering over temp faults, and I thought it was due to interference / noise being read by my VESC so I just unplugged the temp sensors.
Reading all these threads has me now wondering if my motors were actually overheating and faulting on hot days⦠HMmm
Looks good! Did you spray the heatsink purple here?
Looks anodized
Yeah where did y get the purple heatsink from?
Thatās a 3ds heatsink you can buy them here https://shop.3dservisas.eu/products/dual-focbox-case-heatsink-plate
The purple is def aftermarket, Iāve previously specifically asked 3ds about purple anodizing before and he wasnāt interested
Is it sprayed or anodised?
Thatās what I want to know too, hopefully @Soflo will enlighten us.
Hey guys. That is a 3d servisas heatsink.
I powdercoated it dormant purple with the rest of the parts. Iāll be posting a build log today.
