Look forward to reading it
Thatās insane hahah i canāt even imagine
What a sexy board. cant wait to see the build log
I just posted the build log.
Are you making a deck with recessed enclosure?
I did one that would have been a funny kind of ādrop-throughā battery pack. It was supposed to be easy to swap the battery packs. Like this:
It didnāt look good enough so Im making this one kinda standard
is that strong enough?
Whatās up with the sidewall on the tyre in that second pic?
nothingā¦
iām simply showing the āthickening inside the tire at the tread reliefsā⦠these are substantially thicker/stiffer on the running surface than any other 150~160 tire Iāve come across⦠I canāt wait to shred themā¦
Looks awesome, was just concerned for a moment there.
mark center and then drill off center⦠shakes my headā¦
Also, if itās not a state secret, can I have a link for these 155-90 (?) beauties youāve got there? Wait, are those the Metroboard tyres?
metroboard one-fiddy-fivesā¦
ifān you wanna order 5⦠beacuse ordering 4 tires is E-stuupidā¦
from Ian:
Just add this other item to the cart
But mention in order notes you want an extra 155 mm tire + tube instead.
and tubes are awesome not the typical āclever paper-thinā inner tubes!!!
Yeah. So that is tightā¦
Mine was not like thatā¦
It moved that way mid ride⦠And just like last week my wife had to come get me mid ride.
She loves that!
Tightening truck mounts is hard.
I did it this way
Except I used a 0.5mm washer
What order did you tighten the bolts?
Itās big one first then the 4 small ones
That is how i do as well⦠But usually a few speed rings.
Yep.
Big bolt. Then little bolts.
Angle is kind of low and hits my driveway sometimes when I leave the house and am too lazy to pick up the board.
So probably got jarred
With the 0.5mm washer do you now have the rings around the motor pulleys
