I told him I wasnāt kidding, partly cause I wanna see whatās in there.
When Brian takes short boards too far
LoL if it doesnāt have a big fat tail, it better be super long or Iām out
They have so much character man itās unreal. The two laziest cattle dogs youāve ever seen! My blue girl rides eskates and flies with me in the paramotor. Red one is the house protector
How do I get my hands on one of these decks? Iām searching āfathom mini drop deckā or so and everything is unavailable/out of stock.
I got it off of target.com
Is target.com on the trusted vendor list?
Adding now. As well as Walmart, IKEA, and @mmaner 's fav Dollar General.
It was my poor attempt
@ShutterShock, that was quick. Where did you get it from? Regular shipping from China? Did you test the fast charging yet?
Its coated and Theres a fine, waterproof mesh installed above the fan
waterproof mesh? How can air go through but not water?
Its near enough a hydrophobic mesh that repels water until it gets too much pressure. Itās more a just in case scenario, I donāt plan to ride in the rain often
Do you mean the phase wires or the silicone/caps that havenāt been coated?
goretex
more or less waterproof. if i had one point of failure that was ip66 honestly iād be happy
https://www.e-bike-technologies.de/index.php/en/miscellaneous/gore-pressure-balancing-valve/gore-pmf-100600-135-detail
Lol, well actually more of a coincidence, itās not my board, I revamped it for a mate who is quite happy with these, I just fitted a fresh set
Got it from ali express! I love it so far, both of them fast charge both directions. I tried using my Samsung fast charger to charge each battery and both of them fast charged through USB-C just fine. In addition, they both output fast charging capability to my S10+ just fine. I tested them with my TS-80 and both of them powered it fine. Thereās a little ticking? / coil whine / buzzing sound on occassion when using the higher fast charging modes (ts-80 uses 8v), not sure what thatās about but it didnāt seem to affect itās functionality.
Downside of sealed motors I guess. 86F isnāt that hot outside though, what kinda amps you running?
I have problems with all types of motors in summer, also open cans. There is a magic temperature threshold of about 24-26°C (75-79°F). Below I have almost zero problems, above the motors overheat every ride.
100 motor amps ![]()
I could decrease to 80A but it makes no difference. Maybe 50A would work but thatās lame.
Last summer I had 6384 motors with open cans (80A) and was so desperate that I built this ridiculous 12V cooling setup powered by a 3s1p.
Well it worked but only during riding in reverse (or standstill) because there was no space to mount the fans in the direction of the natural airflow ![]()
Thatās crazy haha you must be on the larger side huh I donāt think my motors ever really struggle to push all 160lbs of me lol
