I’m liking ALMOST everything about Orange one…
Need more wheelbase, shooting for 42"
I don’t know about the gaspedals, Probably design it with progressive concave or maybe simple radial concave
I’d like more drop… I need about and Inch (yeah, that’s what she said…)
and about an 1" of rocker, (camber front to back) to aid in torsional rigidity…
concave top, flat bottom with wire channels between the stiffening spars so I can make simple bullet-proof enclosure…
Honestly I’ve been beating my head against reality trying to make a alum. monocoque esk8 race-board… this is almost there!
off to Fusion I go…
@surfnacho If’n I can get you the shape I want, can you CNC me a wood mold to press this against?
From 313:
Vorgaben: Alex Dietz, Boris Schinke
Konzept: Peter Scheerer
CAD/CAM: Verena Völkel
Konstruktion: Peter Scheerer
Fertigung: Peter Scheerer, Verena Völkel
Grafik: Verena Völkel
Concave: doppelter Löffel progressiv, Welle, Gaspedal, hinten: „Pushedge“
Längsprofil: Wavecamber (5º – Rocker – Camber – Rocker – Kicktail – 0º)
Handrails
Doppel-Diffusor
Schaumkern 10/5/15 mm
ABS Nose + Tail, Multiplex Inserts
Lagenaufbau: 6 Achsen Glas / Carbon
Oberfläche: PU-Lack, klar
Hitzegehärtet
1550 gramm (3,41 lbs)
Länge: 1000 mm (39,5″)
Breite: 265 mm (10,5″)
Radstand: 750/771/792/813 mm (29,75″/30,5″/31,25″/32″)
Input: Alex Dietz, Boris Schinke
Concept: Peter Scheerer
Construction: Peter Scheerer
Manufacturing: Peter Scheerer, Verena Völkel
Graphic: Verena Völkel
Concave: progressive double-spoon, wave, gaspedal, „push-edge“
Profile: Wavecamber: (5º – rocker – camber – rocker – kicktail – 0º)
Handrails
Double Diffuser
Foamcore 10/5/15mm
ABS nose + tail, plywood inserts
Layup: 6-ax glass / carbon
Topcoat: PU-varnish, clear
Heatcured
Length: 1000 mm (39,5″)
Width: 265 mm (10,5″)
Wheelbase: 750/771/792/813 mm (29,75″/30,5″/31,25″/32″)
