Boy oh boy that’s tight. Looks just long enough. Any issues? Is that outside bearing riding on the axle threads?
My thoughts exactly do you already have the 220 hangers?
uh oh
Yup, looks like the nyloc barely even grabs the threads…
then again I’m using zealous bearings also
I’ve never actually rode with these pulleys before, so I can’t report on any issues…
I did. I imagine their still sitting on a dock somewhere in California.
The aluminum flange should sit directly onto the kegal core
Definitely not enough threads
What’s the axle length on the truck?
That’s a DKP truck
yup… I thought so, nylon definitely doesn’t even touch the threads, even w/ normal bearings.
push the pulley harder into the wheel, the kegel core holes wall is not straight (whatever the correct term for it)
e: conical hole? i think? i don’t know what it’s called
I know this is a different brand, sorry, but this procedure might work well if the pins are tight.
They’re fully on there, here’s them with some non built in spacer bearings w/o washers:
The nylon grabs the threads this time, by only by a half bolt turn.
then i don’t know, i can also check my set once i have them on hand
u got washer on there?
This; maybe getting some 0.2mm axle washers (speedrings) would be of benefit over the standard 1mm type.
I’ve used them before but they are very difficult to source.
…and sometimes you think you find them, but when they arrive, they just barely won’t fit on the 8mm axle…
I believe DKP trucks have a 55mm axle (bn trucks are 50mm)…? You think could show me a picture of the pulley properly seated in the tb110?
here
Nope, with a washer on it’s exactly like the picture w/ the zealous bearings.
who wants some 36t pulllleysssss, ill trade
