bad esc programming/ or poorly made (playing with the settings without knowing how it works)
BMS (not bypassed and being pushed beyond capacity)
weak voltage from battery (can cause a reset on your board)
vibrations causing something internal to break (receiver would be my second reason for a crash)
and battery improperly made (usually pre-builts that aren’t made for safety, but for money)
The best you can do is simply buy from trusted vendors on the remote and try not messing with your esc, other than what is only needed to be messed with. And to not go beyond what your esc can handle, and what your battery can output. Some crashes would be from ERPM limit shutting off your remote. This one sucks.
So, the remote losing connection or shutting off will lock the weels?
I got the Stormcore 60D+ here today, so hope it will work fine.
Battery will be from a very reputable guy here on the forums.
No. That is if you programmed your esc to “force stop” if ppm signal is lost to the esc (hobbywing does this, and I hate it). I turn mine off. You can lower the amps on that system so it doesn’t throw you off, but slows you down to a stop.
Edit: stormcore is a good esc for what I’ve heard. So it should be fine.
Sounds good man. Thanks. Feel a bit better now.
Will pad everything down and make sure all parts inside is well supported, and use a good dampening material.
Can anyone recommend a stealthy way of running motor/sensor wires from a bottom and inward mounted motor to an enclosure that is top mounted? Basically TB mount/trucks which will be need to go to a top rear mounted enclosure. I looked at tunnel risers but they seem to be for routing to a bottom mount enclosure.
Does anyone know the exact outside diameter of 8mm x 22mm skate bearings? Apparently Trampa’s “9.52” axle bearings are 22.22mm, and it seems as if 8mm skate bearings really are just 22mm, or less, even. I can’t seem to fit Trampa’s 22mm bearings into TB110’s.
So I don’t have to worry about breaking this kegel core, I just need the right kind of pressure? Are 8 x 22mm skate bearings also oversized by .22mm?
I think than maybe I can use the axle itself to put the bearings on. I’ll just put a big washer over the bearing, and use the nut to tighten it until it seats.
If I wanted to wire up a buck converter with a switch, does the voltage rating for the buck matter? Is a 12v rated switch fine between like a 50.4V pack to a buck (assuming the buck can handle 50.4v and that current ratings of what we want to power are within spec)?
If the switch is between 50.4V and the buck, then yes it matters and the switch has to be rated for that voltage because it needs to switch that voltage. If it’s after the buck, it only needs to be rated for a bit above 12V or whatever the output is.
Generally though - with a lot of asterisks - it’s the current rating of the switch that’s likely to cause issues. Low voltage switches aren’t reeeally a thing because you need huge voltages to arc across the distance of the switch, but low current switches very much are a thing because the small ones can’t handle more than (or even at) what they’re rated for
