centre post
The only dumd question is the unasked one.
centre post
I’ve never seen any esk8 equipment wired for negative center, but it could happen.
Put a fuse on your charge port, always
https://www.mouser.com/ProductDetail/Littelfuse/0997075WXN?qs=bpnLQM2ZShwcHyOYzoHBAA%3D%3D
Better low speed braking, better heat capacity/dissipation potential, better power potential with bigger batteries.
I see some metr logs with 70/80km/hr around here and i can’t wrap my head around that honestly.
Also, moar flex potential, duuh
i had an old charger that had a negative center pole but it wasn’t for esk8
I would try to get a fiberglass enclosure if possible. ABS is kinda shitty and breaks really easily, especially with a lot of cells inside.
Check out @eBoosted @BigBen @glyphiks and
Or you could get an ABS enclosure, fit it, then use it for a fiberglass mold. Not sure if anyone has done that. Anyone have any reason that wouldn’t work?
5.7cm that will be pretty fat
do you have enough clearance for that
also the enclosure will be very wide since your batteries are pretty wide
i also have to know the concave could you try and measure it?
Same, why did my post get flagged then?
I don’t know; I didn’t flag any posts
You should get a message if the post was flagged; you can ask in there
Ah cool, thanks for this!
The esc they’ve got is the SV4 not dv4 as you have. If i wanted to improve the breaking would getting a vesc6 help? The battery config really depend on whowmuch my enclosure will fit. Im thinking of a double stack, in which case it would be 12s4p…but that may be optimistic and its likley ill go for 3p like you
I put a spot for taping in a filter and using carbon filter made for soldering fan in there for now it’s not going to stop water from flowing in but I figured I can just swap back to the sealed case for winter time and just try to avoid deep puddles in the summer and have the filter in there in case I have to deal with a little rain.
Also I use silicone conformal coating on the pcbs in there for the most part so a little splash shouldn’t cause any harm even if it did get inside.
Is this the nail polish like stuff that kind of waterproofs your electronics?
Yup @b264 has some write ups about it but is basically just clear coat that adds layer of rubber over all the electronics I left the mosfets mostly bare of it but basically paint it on like nail polish let dry for like 20min then give a second or third coat, can check where it got with a UV light to make sure all the contacts or metal parts that could rust or short get covered.
https://www.amazon.com/dp/B008O9YIV6/ref=cm_sw_r_cp_apa_i_Gkt7EbD0XH18S
Some stuff you can solder through other stuff varies in different ways.
If using that stuff too just do it in a well ventilated area or outside the fumes seem pretty nasty on the plus side it dries pretty fast.
I actually now prefer the MG Chemicals #419D for electronics and MG Chemicals #4223 for big wires and connectors
and MG Chemicals #4228 for motors unless they’re getting the better battle-hardening treatment
What does happen if there’s splash water in the motor and what does happen if there’s much water inside?
I had splash water inside, and it worked flawlessly, and spit the water out when driving like a shaking dog…
Too much water results in shorts between the coils?
Edit: Google says the water isnt a problem for electric stuff that happens inside the motor, but the bearing will suffer corrosion if you don’t relubricate it.
Is that true?
Hi everyone, this is my first post!
I m making plans for my first board, should i post here or open a thread?
I m a mechanical designer with a 3d printer and access to laser cut, I m also lucky to have friendly collegues that could help on making a li-on battery
My plan is to start with a single motor belt build, with a 3d printed enclosure on a cheap longboard i already have, then upgrade to dual motor on a homemade deck if i like the hobby and want to spend more.
I wanted to stay on the cheap side so at first i landed on Flipsky website, but after reading many horror stories i m not sure, i may be more inclined to buy motor and esc from Maytech.
I was thinking to go 6374, FSESC 6.6 or MTSUPERFOC6.8 , 12s2p, VX1 remote, homemade laser-cut motor mount.
Any advice?
Ps:I already have a full helmet and pads
This is the place for questions, but we have another thread dedicated to introducing yourself and sharing your plans:
Good motor size for a single motor build! For dual motors, 6355 should be enough, but if you already have one 6374, you can go dual 6374 without paying too much of a premium.
Pleas note that this will require wide trucks down the road, so better buy 220mm trucks from the start, I made the mistake not to
A little larger wouldn’t hurt if it fits your budget.
Good luck with that ![]()
